Bilstein Sport shocks installed.. Well the fronts..
I will replace my 02SC430 front shocks with Bilstein HD for GS400. Is it necessary to replace any other part, ie., upper mounts, etc. for the shocks to fit or the shocks are direct replacements?
pearlpower
i don't know if your still here, but heres an update for you: The Bilstein Sport GS300 Dampers fit the 430sc in the front. the rears just need the bumpstops cut 1-1/2" for the Bilstein Sports to fit.
Or you can do it the right way, send them the front Bilstein Sport Damper and have them revalve the Fronts for the 430sc.
also send them a photo of the stock rears 430sc dampers with all the measurements of the stock dampers and with the rear Bilstein GS300 Sport Dampers they will cut the Damper Body and Rods, Revalve them to fit the 430sc..
then you have Bilstein front and back.
Hello from Australia, I realise this is an old post, but would be grateful for any feedback/advice re the IS300 rear bilstein shock for my 2005 sc430. I have looked at other shock options but having driven a few cars with bilstein shocks, I REALLY want some rear bilsteins. many thanks
So it has been a year that Ive had the fronts replaced with GS Bilstein shocks. Still going strong. I have got to replace the rears but want to know if the IS Bilsteins do fit. Can we have a positive confirmation please from an actual owner?
OK guys,
newbie owner/CL forum member still confused:
My '02 SC430 garage queen still only has 50k on it after me drivinrsg it all over the place for two months.
I replaced the "pie plates" (even tho their look started to grow on me) for '07 OEM SC430 five-stars,
Anyway, even though the miles are low, I think the shocks are soft and wallowy (but no probs or noises or bottoming) and I would like to upgrade if economical. Looking for improved handling with decent ride compromise so "hipendicul" 's experience sounds encouraging, but "ZensokuD1" seems to not recommend them.
What's the last word on shock replacement, and what are the part numbers?
Thanks!
Thanks!
Yes, it would be great to get confirmation whether the IS Bilsteins fit the rear of a 2005 sc430. Anyone know for sure pls ? i am looking forward to the bilstein difference ! thanks
Can we have our Lexus parts partner chime in please? All we need to know is if the rear shocks of IS and SC have approximately the same physical measurements and layout/ placement for bumpstop, etc. Never mind the valving etc. We'll deal with that issue after someone's had it installed. A picture showing the side by side comparison of stock IS and SC shocks would be nice. Who knows we may end up buying IS shocks instead of Bilsteins.
Im confused because previous post indicated that the SC stock rear shocks are a few inches shorter than the GS'. Which means that ithe GS rear shocks might be too long for the SC, let alone a lowered SC. Do you have a pic or illustration how you did it?
...hey guy sorry for the late response...I read threw many threads here before making my decision. The best thread I came across is titled "aftermarket shocks & struts by ultima"...type this into the search box & it should come up. Then start reading @ post # 20. He details what he did exactly & I followed it to a tee.The only thing I might do differently, would be to leave the bump stop as is or not cut as much off them. I didn't take pics of the set-up or install (sorry), but can definitely say that it worked !!! If you need more info or have more questions, just pm me or possibly Vtur, he's the person who did it first & posted it in the thread I suggested..hope this helps some
