Bilstein Sport shocks installed.. Well the fronts..
Old 03-04-13, 09:32 PM
  #31
whitels
whitels's Avatar
Originally Posted by texsexlex
...hey guys thought I would jump in,since I just did this. I used Bilsteins for a GS 300, instead of an IS.In some of the old threads, the GS shock is whats suggested, so I'm not sure about the IS .I dropped the car approximately 1.5in all around & put Bilstein on the back. I cut the bumpstop in half to give them the same travel as the stock setup, as suggested. I'm running 18 x 9.5, with 25 offset,in the rear & haven't experienced any rubbing of any kind. I love the handling now & it really rides greats. You do feel the stiffness on bumpy roads,but other than that,everything seems to be fine...hope this helps some
Hi texsexlex,
Did you install the Bilstein HD or Sports? It seems that the Bilstein Sports has shorter body than the Bilstein Heavy Duty (HD) version. That being the case, the Bilstein Sport would allow for wider up and down travel motion (compression-decompression) before hitting the bump stop. But I could be wrong in that the HD picture is shown only in compressed state below.
Picture of Bilstein Sport follows below ...
Attached Thumbnails Bilstein Sport shocks installed.. Well the fronts..-image.jpg
Old 03-04-13, 09:35 PM
  #32
whitels
whitels's Avatar
This is the Bistein HD version (below)
Old 03-04-13, 09:36 PM
  #33
whitels
whitels's Avatar
This is the stock 2002-03 SC430 oem rear shocks
Old 03-04-13, 09:41 PM
  #34
whitels
whitels's Avatar
Picture of IS300 Bilstein HD follows next ...
Old 03-04-13, 09:50 PM
  #35
whitels
whitels's Avatar
Default More SC430 oem factory stock rear shock pics
Rear stock shocks
Old 03-04-13, 09:51 PM
  #36
whitels
whitels's Avatar
Upper part of rear oem sc430 stock shock
Old 03-04-13, 09:53 PM
  #37
whitels
whitels's Avatar
Part number for 2002-03 oem rear shocks
Old 03-04-13, 09:54 PM
  #38
whitels
whitels's Avatar
It is made by Tokico, not KYB as most people had previously thought...
Old 03-04-13, 09:55 PM
  #39
texsexlex
texsexlex's Avatar
...I did the sports...they will also come with the spring bracket/holder so that your stock or after market springs fit perfectly
Old 03-04-13, 09:57 PM
  #40
texsexlex
texsexlex's Avatar
...yea there were some different answers to the rear shocks & who made them. It may have depended on what year the car was, but can't remember exactly
Old 03-04-13, 09:58 PM
  #41
texsexlex
texsexlex's Avatar
...so did you buy the rear oem's ??? are just using the pics to compare ???
Old 03-04-13, 10:36 PM
  #42
whitels
whitels's Avatar
Just using the oem pics to compare. Thanks.
If your car is lowered and mine is not, then maybe I can get away without the need of cutting the bumpstops - if or when I buy the Bilsteins. Does that sound about right?
By the way, what springs do you have and what shocks do you use in front?
Appreciate all the info.
Old 03-06-13, 08:30 AM
  #43
whitels
whitels's Avatar
Shockwarehouse.com was nice and responsive enough to accomodate my request for physical measurements of various Bilstein shocks I'm considering for my SC's rear.
Bilstein
24-060493: for IS300, Heavy Duty
Collapsed Length (IN): 15.79
Extended Length (IN): 21.5
Collapsed Length (MM): 401
Extended Length (MM): 546
24-027441: for GS400, Heavy Duty
Collapsed Length (IN): 16.89
Extended Length (IN): 22.32
Collapsed Length (MM): 429
Extended Length (MM): 567
24-028035: for GS400, Sport
Collapsed Length (IN): 16.93
Extended Length (IN): 21.67
Collapsed Length (MM): 430
Extended Length (MM): 550.5
Sent from Shockwarehouse.com on 05/03/2013 @ 01:26 AM
Old 03-07-13, 10:16 PM
  #44
texsexlex
texsexlex's Avatar
I definitely think you can get away without cutting your bumpstop. I'm actually going to order some new "stops" for my car & see if there is a difference. I love the ride & handling, but those occasional "hard bumps", lets me feel it. It never bottoms out, but can be jarring at times...lol. I'm using the KYB shocks up front & the Bilstein shocks on rear. I also have the Tein S-Tech springs that I bought from Z3NK1, a fellow club member
jbone29
Suspension and Brakes
12-31-21 10:33 AM
Simmsled
07-08-20 02:10 PM
DexRox512
11-17-09 07:45 AM
GS400kid
03-16-03 04:26 PM
cong28
05-18-01 02:41 PM
Quick Reply: Bilstein Sport shocks installed.. Well the fronts..
