emblem removal
I want to replace the rear with black pearl emblem, is it a glue type or screw or pin?
I noticed some SC with the stock grill with no emblem how do you do that, If I remove the front emblem is there a gap on the grill or does it look clean grill like I see on some SCs
Grille first. All models up to '05 have the 'L' stuck on, and can be removed. It's just a matter of blacking out (permanent marker, etc) the plastic tab where it mounts; that makes it pretty much invisible. The '06 has the 'L' built into the grille.
All emblems can be removed except the 'L' on the back, which has 2 pins, and the corresponding holes in the trunk. That's the only one I left, because it's also indented into the trunk, and would look like crap without it. It's pretty easy to remove if you just want to replace it with a black chrome one. Just remove all the adhesive before sticking the new one on. Good luck.
NormandyIS
02-13-13 11:55 AM
