Center Panel Removal / Cup Holder Assembly Removal???
Any kind soul help me out with removal of the center panel where the stick shift is as well as if it is possible to remove the cup holder assembly without pulling the whole center panel. I popped out the heat seat assembly very easily but can't figure out how to lift the rest out. I am looking at a way to utilize the cup assemply such that I can remove the right side of the cup holders so I can use the base of the assemble to install my Pioneer INNO XM radio. Can the right side of the cup holder portion be removed? Any help would be greatly appreciated.
once you pop the heated seat buttons, you can put the wood trim as well (pop the back first, and then pull the trim at 45 degrees angle up away from the console, and it should come out
that's as far as i went before, but i think after that you should be able to figure the rest on the cup holders
David
I'd assume EVERYBODY would love to see a pictorial of the procedure... if you're so kind to do it.
In fact, there should be a sticky with procedures of things to do to our car, or better yet, a 'technical' sub-forum for our SC430, like in most boards.
A search is many times frustrating, as the subject is not what makes sense, and only way to find a previous post that we know about is reading like if we had nothing to do. Maybe with a technical sub-forum people would be more inclined to document their modifications, like you plan to do for us. Maybe that'll start it all
. Take care.
