SC430 Reverse camera/DVD Installation
I think Lee said he was going to use an FM transmitter. Not the best option for quality but probably one of the easiest options (in terms of install). My gf will be using the dvd player mainly to watch & listen to music videos when she's in the passenger seat while I'm driving. So yeah, I'd like the best solution for quality sound as well.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
thanks for the note jimmy, i knew i was tired
anyway, fm... definitely not the best solution. come on lee, you have to do better than that
if there is another unit to add to the system to act as another input, i guess this becomes very very much like the viastech stuff huh
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
You guys are correct that FM does not offer the best sound, but the SC430 ML is not 5.1 surround anyhow so any input is not going to get the best audio out of a DVD, FM will do just fine. My Ipod is on an FM and it sounds fine to me without the clutter of tape adapters and has no static. Some other FM's out there are horrible. Suppose it depends on what has been experienced.
To splice into the ML would require another toggle switch to feed the sound and I am not much for toggle switches in my cars. The FM route is the safest and simplest approach to a system that does not accept surround sound to begin with. I suppose one could just splice into the left/right input lines going into the amp in the back of the car but I would hate to see what would occurr if two seperate signals were fed at the same time-could just be static-could be something not too pleasant.
Sort of a trade off with the Viastech units as those do not offer the reverse camera auto switch but offer direct audio/video the last i checked. So this unit is geared more for the backup camera vs the Viastech which is audio/video and to use a camera would require a toggle.
Best bet is to get both units and use them for their primary purpose.
Lee
Lee
Looks really good (means alot coming from me) - actually makes the carpc thing kind of interesting all of the sudden. I really wish there was a way to get the touchscreen on the NAV LCD presented as usb or ps2 mouse, but chances of that happening are slim to none, I'd guess.
Anyrate, this device with a carpc syncing mp3s via wifi could be really nice, only downside is need for a remote control vs factory controls being usable.
I just might do it ...
The problem with the SC is the darn cover. Let me ask you this: What happens if you have the screen off (and cover lowered), and you put car in reverse? It might open by itself and turn on; who knows. If not, you're probably screwed. I still don't have the service manual for my MDX to see where is that interface.
The ideal installation for me (on the SC) would be to have a switch to turn the feature on and off, and when ON, that the door would open and the screen come on when car is put in 'R' (just like a factory feature). After getting out of 'R', screen would turn off and door close. I said with a switch because I'd rarely use the feature, and it would prevent wear and tear on the door opening every time you drive away (and screen tilt mechanism as well). Good luck buddy, and keep us posted.
JC
thanks for the extra info, lee. when you come up for eos (you better come ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
), i wanna listen to your car playing even and see what it's like. i really like the fact that this unit plugs in so easy in the trunk without pulling everything or splicing any wires, plus it automatically turn on the video when going to reverse. very nice stuff
somehow i thought for vaistech it goes to reverse camera too automatically when you put the car in reverse. guess i was wrong
man that is a realllly nice set up, looks like it took about an afternoon or so and works great. How hard was the wiring of the unit? And, how much did this all cost? Thanks
Lee
Lee
Cost on the unit was 199.00 +shipping. Camera is extra.
REDMR2, I tried the $90.00+ brand name units, the $50.00 units, and everything in between and this $20.00 unit works best from Ebay.
https://www.clublexus.com/forums/sho...highlight=ipod
But for this setup I wull be using something else.
I've been considering doing this video mod too.
However, if anyone is doing FM modulation for sound, they have to take the time to install / hear something like this:
http://www.vaistech.com/sli.html
It's day and night..
I've got this installed with the Drive and Play Plus with my Ipod and it's the best thing I've ever seen - completely clean, very very easy to use.
Not sure if I want to buy the video thing and the camera on top of it![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Eric:
'03 SC430 Blue
Eric:
'03 SC430 Blue
Not too sure where the DVD player will be installed. Two spots are in the glove box (limted space) or in the right rear compartment in the trunk. As far as the FM modulator is concerned, I am waiting for a simple one to arrive to try it out and will post at that time. I should most of it going next week but the LSD install will take priority so we shall see.
Lee
just wanted to comment that this is a nice install and great info thanks for taking time to do it ! also please keep us updated on the fm transmitter as im very interested in this as well.
also if you can give me your input on this topic
https://www.clublexus.com/forums/sho...d.php?t=234995
Hi Jimmy
Lee
Lee
