I Finally Replaced My Runflats!!!!
Tire Pressure Question
I am getting my RFs replaced today with the Sport Pilot. Any suggestions on the tire pressure? I have been using 39 on the Dunlop RFs.
Just hope the new ride is all people say it is. Presently rides like a Jeep. My Dunlops are actually falling apart at the seams after 25k of light driving on good roads.
I just had my RFs replaced with the Pilot Sport tires and, so far so good. I am now aiming for potholes. Not quite, but close. What pressure should we use in these? I know 39 was recommended for the RFs to "smooth" them down. Oh, no more tramming that I can tel. That was one of my biggest complaints, other than loose fillings.
Proper pressure
Well finally I di replace my RF tires with michelin Pilot Sport PS2. There is ahuge difference as everybody else says. I hope to sell the RF tires on ebay. I hope I can find some takers.
I have one more question. What is the proper pressure for the tires in this car? The manual says it should be on the side of the Driver side door. However, in my car there is no such information on either side doors. Can someone look at the info in their car and tell me what should be the proper pressure of the tires. For reference I have a 2003 SC 430.
Thanks
fatih
Thanks
fatih
Thanks
fatih
Thanks
fatih
rule of thumb, ALWAYS ALWAYS measure tire pressure when COLD, nothing else. measure it after you wake up in the morning and the car has not been driven at all (in the garage). that's the only accurate measurement. anything else is not. the ambient temperature outside has absolutely nothing to do with the temperature inside the tire, which is the important factors. depends on your driving habit, road surface temperatures, etc... the temperature inside the tire could vary a lot
that's why, ONLY do it when cold.
with that side, on 18s? usually i recommend about 35psi cold. 38psi the most imho
Benefits:
Larger molecules don't work their way out of the tire as easily. (Tire will not lose air as quickly)
Nitrogen is inert (less water, etc.) so it isn't as susceptible to pressure change with temperature.
Downside:
Cost? (Expensive for the shops, but negligible for the customer.)
PS: Can't wait for the tires to wear out on the SC.
Downside:
Now, if you check your tire pressure in your garage at 80º, and you park it outside at 60º, when the temperature equalizes (change is not immediate, just like when hot food starts getting cold), air inside the tires will also be at 60º, and 2 psi lower in pressure.
By the same token, if you start driving right away under the above scenario, you'd be fine then, but still be 2 psi lower the day after.
When temperatures start to plummet, is more important to check air pressure more often. Inversely, you hardly have to add air from winter to summer, because rising temperatures usually offset normal air leakage, and pressure seems not to fluctuate at all for a long time. Good day.
IStoSC
08-17-11 10:47 AM
