tire squaking from 1st to 2nd
Today a new SLK 350 drove past me with an automatic transmission. I guess it had the semi automatic in it. When it went from 1st to 2nd the tires let out a small squeel and you could just see the power.
I have almost red lined my 06 sc before up shifting between 1st and 2nd and 2nd and 3rd and not a sound comes out. I guess the base SLK has more???
I have almost red lined my 06 sc before up shifting between 1st and 2nd and 2nd and 3rd and not a sound comes out. I guess the base SLK has more???![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
To answer your question, yes, that little V6 SLK will easily smoke you every time, so spare yourself from the embarrassment next time
. Much better power-to-weight ratio; it's almost a second quicker to 60, I believe. Later.
I've read in the mag's that our SC430's did 0-60 in 5.8 seconds and the SL500 does it in 6.1 seconds. So you are saying that the little V6 SLK does it in 4.8 seconds.
Never seen the SC quoted below 6.2 on major magazines. And even at that, I would NEVER subject my car to the abuse needed to reach that figure (imagine to get 5.8?). The SLK is 5.3 I believe.
But forget about the darn numbers (geez); the SLK smokes our SC all day long; that's the bottom line.
