Trunk won't stay open
The shocks (or whatever) that keep the trunk open have gone bad (ouch on my head). Of course it happened a month after my warranty expired. They look easy to replace. Any suggestions on where to get them, cost, and how to install? I don't like going to my Lexus dealer. They make me feel like a criminal for not changing my oil every 5k, changing my own filters, etc, etc. etc.
I believe I recall reading here a few years ago that it is not a standard strut, and that it is a Lexus only part. This makes it an expensive replacement.
All owners whose cars are still under warranty should mark their calenders and check the trunk lid at the 4 year date to see if the trunk lid shows any signs of not staying firmly in the up position. (Really, really firmly.)
I did that after the eariler discussion here, and noticed some weakness; I mentioned it to the dealer and they were replaced without hesitation or comment by the dealer under warranty. My car is about 6 years old now, so I guess I have 2 or 3 more years to go on my second set.
DIY only $225 for the pair for being a CL member. Installation Is a breeze. Save Hundreds of $$ from the dealer.
http://www.lexus-parts.com/partdetai...bCategoryID=52
Now that you mention it, my '04's trunk slammed on the back of my head the other day, and never did that before. Still have a year left in the warranty, but I wonder what's the right test. I know it shouldn't come down on a flat surface, but I expect it to also hold itself open at a slight incline, no? Dealer should perform some kind of test as well, or do they just replace the shocks because you tell them to? I doubt it. You know how dealers want everything duplicated; I just want to know their test to know when to take it.
Thanks.
Thanks.
My dealer took my word that the lifting and holding power of the struts was not as strong as it was at the time of purchase, almost 4 years earlier.
If it's under warranty, the dealer is not out anything by replacing them, as far as I know about how warranty repairs and replacements are done. In such instances, the manufacturer pays the dealer for the part and pays a fixed amount for labor (I think). If the service guy beats the clock, the dealer will make some money on the deal, and I don't think it takes long to replace these struts.
In any event, if the trunk lid slammed down on your head, the dealer should take that report pretty seriously, as nobody likes to have a customer go toes up from a whack in the back of the head (usually).
Many dealers will replace the struts if they are weak and under warranty. It does rank as a safety concern. This usually carries a high priority for the customer, they will take you word if they feel weak to lift or hold the lid, or it has fallen on your head.
This is compounded if the rear lid has a large piece of glass, as with the SUVs.
They do wear and get weak. And they need to be replaced in pairs. When replaced, you will notice the difference.
A little more effort is needed at first to close the lid. This will pass, and the closing will return to normal.
exclusive matchup
Super Moderator
I've never had any problems, mines is low mileage & not used a lot. But warranty is still expiring next month for me at 4 year anniversary, may be I'll try to get them examine them closely . . .
Thanks
Think I'll order them from Sewell along with some other supplies. Any hints on how to install the new ones? Seems like they are easy to get to when you put the roof half way down. But I may bust something else?
If you are going to park the roof in the half-way position, the best position is when the rear window is in a vertical position; this seems to put the whole roof in equilibrium, and is also an excellent place to put the roof when you clean the inside of the rear window and when you treat all the gaskets with 303, as I am sure you will want to do at least two times a year.
Have fun.
Have fun.
I got the supports for the trunk. Sewell said it was a single bolt that kept them on. Someone on this thread said they were metrically threaded and it is easy to see how to replace them when I get the new supports. Neither makes any sense. I see clips on the ball ends that look like they must come off in order to deinstall and install. But the only way to get to the bottom ball is with the top half open and the support completely compressed. The only way to put them on is with the supports in their expanded position (which makes the bottom ball impossible to get to). Any heip? What am I missing in this simple installation? Thanks.
Got it. The clips have to be removed from each of the ball ends with the roof open/trunk opened position -- the supports will be fully closed in this position. Take the clips off. Then close the trunk using the close roof function and open it normally from the rear. This allows the supports to be in their fully extended position. Simply pull off and put the new supports in their place (after taking the clips off of these units). You can put the clip on the top *****, but the bottoms are hard to get to. So you open the roof again enough to get the trunk up. Putting the lower ball clips on is a snap at that point. Never did see any bolts or metric fittings. Just hard to get to clips. Probabaly a 10 minute job the second time around including washing hands. Wonder what Lexus charges?
