transmission oil change maintance?
Hi! I would like to know how often transmission oil needs to be changed and what kind of oil is the best. My car has 45.000 miles and it has never been changed, is that fine? Thanks
I'd NEVER leave the tranny oil that long. I'll 'drain and replace' it every 15K miles, since you can only drain about 1/2 the volume at best.
In your case, you'll probably have to flush it, but I don't like doing that. Or change the oil 3 times in succession (50 to 100 miles apart). I liked my Navigator because I could drain the converter, but Jap companies don't put a drain bolt. I'd rather do a 3X drain than a flush, even if more expensive, but that's just my opinion. Have heard horror stories about flushes, even in relatively new trannies like yours, so I'm a big-time skeptic on those.
Pour a few drops of oil on a white kitchen towel. Hopefully oil is still red; if brown, you'll need a rebuild a lot sooner than normal. Plus you'd have to replace it like NOW. Good luck, and keep us posted.
MultiTasking Mom
my dealer does it at every 30k major service. i'm at 55k so i have had it done once. the next one will be in another few months. i haven't had any issues with them doing it at these intervals.
Edit: oops, sorry, i thought this was the RX forum - i don't know if the procedure is the same for the SC, but i think it probably is.
I knew a guy that was a transmission industry expert, he told me that transmission fluid never wears out. It's in a sealed system and any wear metal is caught in the magnet. He said that the only thing that will ruin transmission fluid is heat that is higher then what the fluid was designed to handle. Normally in a passenger car that is driven "normally" you would never need to change the fluid. Trucks that are worked hard are different or cars that are raced or abused. Your Lexus maintance manual never indicates that the transmission ever needs to be serviced. So I would say that you could put a couple of hundred thousand miles on your Lexus and never have to service the transmission as long as you don't abuse it. Now after telling you what the average consumer can get away with, I have to say that I have any car that I've owned transmission serviced every 30K miles and have never had a problem, but per this transmission expert I would not of had a problem if I never had them serviced???
Thanks for the info.
Well the car is 2002. I habe bought it used and the previouse owner told me that he did not maintane the car at the dealership and he had never changed the transmision oil. So I guess I have to do it now. But I just whanted to know where will be the best place to change it and what type of oil I should use. Thanks
I'd also do it at the dealer this time around. They know these cars, and can tell you if something doesn't look good. By the way, request to talk to the mechanic doing the work so you can pick his brains.
And just like Max commented, fluid can still be okay, but tranny fluid DOES burn (fluid turns brown), and at that point, you might as well have water in there, because it's not going to lubricate crap. Prolonged idling in hot weather is brutal to fluid (bumber-to-bumper traffic, border crossing lines, etc), and even some of that would require the 'severe' maintenance schedule, which is every 15K miles. Pray that the previous owner never subjected your car to any of that.
The good news is a RWD tranny is much more robust than a FWD, and holds more fluid as well. Good luck, and keep us posted.
I just got a quote from the dealer for changeing the transmision oil and it was $375. Regular oil change places qutoing it at $75. What shoul I do know?
Thanks
Thanks
My dealer was $75, wow any other Lexus dealers in your area? What are they doing for $375? Hell the whole 30K mile service at my Lexus dealer is around $700 and they change every fluid and filter in the car along with a lot of other stuff.
