New Strut Tower Brace installed-compared to TOM's
I am pretty sure I ran the Cuscos on my GS400 at one time only because they were multi piece but they were not stout by any means. In fact I could flex the front bar in my hands and I would rate myself a regular Joe in strength. Perhaps the newer ones are better as I notice a few come in Carbon Fiber. I did check the clearance and it does not appear that the Tein motor would fit up top on this unit either.
I wish I had studied Japanese a little harder while I was in college back in Taiwan. It will make my life a lot easier searching these Japanese web sites.
Here is another STB for our car and it is made by Carbing of Japan.
This Carbing STB seems to solve my problem, but the styling and the white color.... not my cup of tea actually.
Whoa! That caught my attention b/c the color matches our car. I can't really see what the design looks like since that pic's rather small. Got any bigger pics, cost & know where I can get it? Thx mang!
I am not too suprised b/c that Cusco STB doesn't look too stout.
Yes, interesting. I have not seen that one yet. Not big on the color but paint is cheap.
Guys, do not flame me, yes this is OLD...
But wanted to talk about Cusco STB's emntioned here. Been looking if anybody's tried it and dies it rub?
Couple of places sell them $180 + ship but wanted to see one installed.
STB-Strut Tower Brace
Purchased off Ebay and received within 2 days I finally got around to installing this thing. For lack of a better name I will refer to this STB as ESTB.
First up before anyone asks-this WILL NOT improve your handling under most circumstances-especially on the street. I know I know ,there are those that swear that a STB has just changed their life-not so! Perhaps on the track things would be different.
That said I have been running a Toms STB for some time now for the aesthetics. It looks nice under the hood. But...it shares a problem with most want to be STB’s on the market in that it is a one piece design and that it is not adjustable.
Comparison:
AESTHETICS:
Tom's stands out under the hood-its silver. It looks good to boot. But the Toms STB rubs on the engine cover eventually wearing off the paint on both the engine cover and the STB itself-see pics.
The ESTB is a 5 piece setup and is very business like in appearance. It is also available with a silver finish.
WINNER: Toss up
FIT/FINISH:
No question the ESTB is superior here as it is a multipiece design like a STB should be. The Toms STB is a very tight fit over the strut mounting bolts and sometimes will even require the car to be lifted to move the bolts around to get it to fit. Other times the Toms STB needs to be bumped hard to fit over the strut tower bolts while at the same time rubbing on the threads of the bolts while going down. The Toms also rubs on the hood lining which wears away the silver paint. At least mine does. Look carefully and you will see the wear on the engine cover and Toms brace.
The ESTB has 2 hats that bolt right on. Two brackets bolt up to the hats and then the main brace is installed. Very clean and excellent fit. No rubbing anywhere. Perfect with plenty of clearance.
WINNER: ESTB with ease
STRUCTURE:
By looking at the pictures one would think the ESTB is flimsy with only 2 bolts holding the main brace onto the brackets. Yes there are two bolts but they are stout and the fit in the bracket is xlnt and even reinforces the entire setup. Pretty solid setup.
The Toms is welded together with decent welds.
The ESTB weighs in at 7.8 lbs vs 6.8 lbs for the Tom's brace and it feels it. The Tom's brace is hollow vs. the solid structure of the ETSB.
WINNER: Toss up depending on what your opinion is. Both are stout and will box your front end.
FUNCTIONALITY:
This is the primary reason I am not a fan of the Tom's or any other one piece STB. Any time they are removed the alignment of the car could change from the shift of the upper strut bearing assembly as there is a little give there though not much. Also by removing the nuts and installing them over and over places wear on the strut mounting bolts-something you do not want to wear out. I did this on my GS.
A multipiece unit just unbolts with the hats still securing the strut mounts so there is not chance of losing your alignment. As often as I change intakes, or adjust the TPS, or change plugs, this is a real plus for me.
WINNER: ESTB
Well, there you have it. Both are great units. Tom’s goes for $300.00+shipping and the ESTB was purchased for $160.00+shipping.
PICS:
COMPARISON
Resting at home after a nice day of mods
Comparison:
AESTHETICS:
WINNER: Toss up
FIT/FINISH:
STRUCTURE:
FUNCTIONALITY:
WINNER: ESTB
PICS:
COMPARISON
I have the type 1 style bar for my xb when I totaled it. Seemed to withstand the damage and didn't bend. Not a bad price tho. The bar doesn't even have the cusco logo on it. It comes with a sticker. I would think it's the same for the SC.
Good question. Probably. The key is the center to center distance of the strut towers.
