Rear Brembo's ?
They look very nice and exact what I have pictured.
About an year ago, a local muffler shop here in Houston actually suggested me to do the same setup.
The stock center pipe has flat spots in the piping right before it hits the muffler.
A more economical way to improve that instead of buying new center pipe is to cut both flat spots off and weld new pipe as some ppl do in Japan.
After that, we can just find any mufflers and tips to our liking.
I personally prefer Tom's exhaust tips to Blitz's because they fill up the bumper gaps a lot better, but Tom's doesn't sell these tips separatetly.
Your SS Corsa tips seem a good match to Tom's.
(To Jimmy, the white SC below has the Answer's rear lip, the same one on my car.)
Nice tips Cecil!
Rich, I know what you're talking about w/the flat spots in the pipings. Correct me if I'm wrong but by replacing those flat spots then wouldn't you need to lower the piping a tad otherwise they'll hit parts of the suspension right above it? I'm assuming that's why Toyota made the flat spots right there (as in, not to hit the suspension)?
Nice tips Cecil!
Tom's center pipe is still flat in that area while Blitz isn't as flat.
Unless you plan to install Tom's lower brace, it shouldn't be a big issue.
Jimmy - I don't hit the suspension, but I do scrape a "little" if I go over really tall speed bumps. You'll have to look at them sometime - you can see the rusty scraped spots.
Rich - I like the shape of those Tom's tips. The Corsa tips come as a pair connected to a single side. They were originally intended for SUV's.
Do the Blitz exhausts also have that restrictive flat spot on their pipes? Maybe I'm thinking of another company's aftermarket exhausts.
Cecil
Cecil
Tom's has to make sure its own lower brace set fit its own exhaust pipe.
In addition to that, I think Tom's wants to sell ite lower brace set to those who still want to keep stock exhaust.
I remember reading some threads that members had fittment issues when they tried to install Tom's brace set with Blitz exhaust.
The pics below are from Jeff's(DPRSupra) old thread.
Nope - Rear Brembo's
FYI, I just got a response from Brembo this morning:
" Unfortunately we do not have a rear Gran Turismo (big brake) Kit. It is only available for the front, but we do have rear Sport Rotors (OEM drilled or slotted rotors). This will give the car some more braking performance in the rear and also match the high performance brake "theme" you are looking for. If you have any questions please let me know."
However, Paul2X suggested as an alternate for larger rear brakes,
" You have to swap the hubs to supra hubs then you can go with a rear kit for the supra's."
If you've gotten this far, you need to look at the post by Lee [Pearlpower] about his upgrade to Rotora Rear BBK: https://www.clublexus.com/forums/sho...d.php?t=256555
