placement of hydralic jack, jack stands?
Hi, where are the placement points for hydralic jack
and where are the points for standing jacks?
this is to do wheel work/rotation, lifting chassis
thanks
thanks
https://www.clublexus.com/forums/sho...d.php?t=251503
post 43. that's where i jacked up my car quick and change wheels, etc...
The issue I have run into with this car is teh cross brace before the differential which blocks my jack so I have to raise the car on one end slightly with a small jack and then place the large jack under the differential to life the rear end. Dropping it is easy as the shocks have not settled and the large jack rolls out before the suspension settles in.
For the front I use the notches on the sides.
smokyis350
04-05-15 09:18 AM
tomtsops
05-20-08 12:54 AM
