Steering wheel shaking...
Hi there Anthony and welcome to CL and to your first post.
Bad struts do not generally cause steering wheel shake. The common causes of steering wheel shake are warped rotors and tire imbalance. Even a bad alignment would not cause what you are describing. I understand that you changed your rotors but can you be a bit more specific to how you changed them. Also why do you say the struts are blown?
Lee
Lee
I took the two front rotors out for a resurface, because my car was squeaking when i apply the brake. then i found out that my rotors weren't repairable due to great warpages on both rotors. so i replaced them with new ones. as for the struts, i found oil runs on both front struts. Wheels are off the 06 lexus RX has new tires... hopefully its just tire imbalance...
thank you again guys and i will update on this problem by end of today...
stevelifts
09-06-20 08:41 AM
