iFORGED 19" Variant Pics!
Nice rims you have there. They look very easy to clean and wax.
Are you sure that is 1.5" drop?
Your wheel gap seems a little too big for a 1.5" drop.
Mine only drops about an inch (Tein's standard setting) plus I am running stretched tires for VIP-style, but my wheel gap still looks a tad less than yours especially in the front for some reason.
I'm guessing at my drop distance. I forgot to measure the original distance, so I measured the distance from the top of the fender lip to the ground on a stock SC, then measured mine and subtracted. I'm sure that you're right, because your ride is definitely lower than mine. Any idea how far off the ground your front fender lip is? Mine's a little under 26" for both front and rear.
It was dumb luck. When we built the house, the garage ceilings just calculated out to 12', and when I decided to add the 4-post lift [http://www.directlift.com/propark7.htm], I had enough space. I'll take lucky over smart any time!
BTW, mine is about 25.5" all around.
