06+ sc430 headlights/backlights on 05-???
SC430 tailights
Hi everyone i am new here i was hope u guys can help me with one question i been reading through the post and i still not sure that i understood it right - i have SC430 and i wanted to change tailights to new 2007-2008 model tilightsand in dillership they told me hew lenses cost me $250 each but they are not sure that it would fit my car - can u please guive me some hint will it fit or not and do i have to get anything else? Thank u for your time.
Welcome!
They will fit for sure-hundreds of us have done it. I am in the process of getting mine much cheaper at either Carson Toyota http://www.l-tunedparts.com/product/?id=1991(less than $800 for the entire set including ECU) or Sewell www.sewellpartsonline.com
They are not as "flat" from a side view as the 02-05 lights and have a slight bubble look out to them, which a lot of people like-it adds a fresh, clean look to the rear.
There are some smaller misc parts that come with the lights-both places I gave to you sell the complete kits, you will see all the parts.
You will need the bottom lights, the top lights, the harness, trim pieces and bulbs for the complete set PLUS the ECU if you DON'T want your lightbulb out warning light on. See my poll about this...
Try hitting the search button for 2006+ tail and there is a plethora of info on this. Good luck. Also look for group buy for carson and sewell or club lexus discount. I believe sewell will give you it over the phone if you tell them you are CL member, not sure...It has worked for me.
Direct link to Carson Toyota for the group buy...
Code: CL06TL
code still works after like three years! Sewell also gives us a discount, maybe slightly higher? Some members have mentioned getting everything for $800 including ECU.
Sewell code: CL911M
Sewell link: http://www.sewellpartsonline.com/***...l=219&year=168
Let us know how you end up, take pics as you install if you can and please post 'em!
Good luck and Welcome again!
Code: CL06TL
Sewell code: CL911M
ashaaro
07-15-12 03:30 PM
quadocox
06-02-09 04:04 PM
