strange gravel noise
Just had my '03 SC in for the 30K service, and since I've gotten it back, whenever i start up and the engine is still cold, there is a sound that occurs that is similar to the sound you might hear if you travel over freshly laid asphalt..... that sound of little gravel getting spit up from the tires. This sound continues for a few minutes and then disappates, but happens again the next time I start up. This morning I opened the door while moving slowly down the street to hear it more clearly, and the sound seemed to be coming from the rear. I got out and looked and didnt' see anything back there, or on the tires!
Does anyone have a clue what this might be? Perhaps it is a coincidence that it started after I picked up my car from the Lexus service.. who knows!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Hey, my brother from another mother. you have the same year and color as I have.
I recently had my 30k maint. and didn't encounter any engine or exterior "gravel-like" noise from my car.
Now, after reading carefully your description, I do have non-runflat Michelin Pilot A/S tires which do have the wider tread and I tend to pick up small gravel, rocks and seeds from the road. Sometimes, these tiny little gravel rocks stick in between my tread which makes a minor sound every time it hits the pavement.
This could be the sympton you're having. Are you still on the Dunlop runflats or non-runflats?
thanks...teeman3
thanks...teeman3
I have exchanged my runflats for the Michelin Pilot Sports, but this sound is much more pronounced than the small rocks that might stick in the tread. In fact, it starts us quite noticeably while backing out of my garage. It seems a little too coincidental that it started the day I picked up my car from the dealer after the 30K service!
thanks...teeman3
thanks...teeman3
Thanks, will check it out tomorrow before I leave for work! I just returned from a friend's house for dinner and the car cooled down, and the sound was as loud as ever! But after a minute or two it was gone. Quite perplexing and also annoying.
Internals of the rear muffler has possible internal rust. You know that creeking noise you always hear on cars from the under carriage once you shut 'em off? That's the exhaust system contracting /cooling. If there has been residual moisture left in the muffler, when you start back up later, it re-expands and you'll hear the same "clicking/crackling" noises from the rear end.....JMO.
I am still perplexed.... Today was more noticeable than usual. But really, it sounds like light gravel being kicked through something, not really like heat expansion crackling noises. Almost like something gravelly got into one of the fluid systems or something.... possible? I am going to bring it back to Lexus this week to check.
Do you have any updates? I am experiencing the exact same noise problem from my left rear wheel. I just purchased a 2002 SC with 31k miles and I did not notice the noise when I test drove the car. However, it just had the 30k service done and the back brakes were adjusted. The noise only occurs once per tire rotation like something is rubbing against the tire. If I go slow it is very noticeable. Once the car has been driven for awhile the noise is much less noticeable. I thought it might be a flat spot on the tire or a busted belt, etc. I plan to have my car checked later this week and will let you know if they discover the cause. Please do the same. Thanks.
update: I am bringing my baby into the dealership tonight to investigate..... The service rep has conjectured that it might be due to the power steering fluid... we'll see.
I am taking my SC in Friday morning and will update. Service rep said it might be due to new brakes or could be a ball bearing issue. Who knows? Let me know what you find out.
Hopefully I'll find out today. A guy at work thought it might be the brake pads (or was that discs) being corroded and rubbing off at the start of the driving day and then building up again overnight. All these theories!
I took my car in last Thursday and they still have it (for other reasons including rattle in wood inlays due to stereo....3rd time in for that)
On Friday, they called to say the problem is that the front tires are wearing and the "whirring" noise I am hearing is due to that. But I gently reminded the service advisor that the not is not a whirring, but a very distinct crackling gravel-type noise. He said they'd go out on test ride the next day to check it out. Still haven't heard back.
