front speakers damaged, are alpinesps 69c3 ok instead?
Hi, I recently bought a used 02 model and the car is great(even with the runflats, can't wait to change them though). The 2 large speakers (6x9 in.) in the bottom of the doors are damaged. Today I will try to put silicone but it's a long shot because are separated in many places. My question is : in case is not going to work I purchased 2 alpine sps 69c3 speakers. Do you think is a good idea ? I don't want to ruin this nice system inserting something inapropriate. Thank you for your opinions.
Damaged speaker?
How did you handle replacing the bad speakers? I have a 2002 SC and the right front door speaker is blown. Did you replace with OEM or aftermarket speakers? Any issues?
I went to a local audio store today to verify if aftermarket 6x9 speakers (Infinity, Polk, etc) could be placed in the doors. The tech informed me that I would have to replace with OEM factory speakers or exchange everything except the head unit (i.e. amp and all speakers). Does anyone know where I can locate good used OEM factory speakers?
Cheers
I posted a question under 'Security, Audio, etc' at the bottom of the home page. This is the response I got for the 6x9's:
From more research it seems the 6x9 is an 8ohm model in your car--
The Tang Band 6x9 sub should be a perfect match--
This seller has a pair and I'd go for those-- Although you may want to inquire with him about the neo-motor shallow mount version he has available with a 3" voice coil--
http://cgi.ebay.com/Tang-Band-6x9-Su...QQcmdZViewItem
I am trying to verify if they will be a direct fit. Let me know how it goes.
I looked at the TB 6x9" but the only one that comes in 8 ohm has a mounting depth of over 4" which is to deep for the door. The window would hit the speaker when it is rolled down. The one that was on Ebay was a 4 ohm one that would fit but would not be compatable with the stock amp.
Cheers
Cheers
I have been umsuccessful in locating new speakers. You mentioned that you had the wiring diagram for the ML system. Can you send it to me? Have you upgraded your system?
sarah
07-22-09 10:01 PM
