Rotors: How hard is it to take the Front Rotors off?
hello, I'm planning on taking the Front Rotors off and front brake pads. They need replacement. I just wanted heads up information before I do the job. I don't have a complete lift system, so basically I'm using a stock jack and doing the job in my garage.
I've replaced front brake pads before, so I'm just asking to see if/how difficult it is to take the front rotors off.....thanks.....
p.s. I bought Brembo OEM plain front rotors from tireRack.
thank you....
thank you....
easy fo cheezy. just take out the two bolts holding the caliper on. I think they are 19mm. take off the caliper and your rotor is floating. Really quick and easy. you might need a clamp to push your pistons on the caliper down so they will fit over the new rotor
caliper braket/housing in the way?????
i did all the steps you told me, but the I can't get the rotors off b/c the caliper housing is in the way, Do I have to take the caliper housing/bracket off so that the Rotors come sliding out?
(p.s.
i took the brake pads off, the calipers are off, but the caliper braket/housing is in the way to take the rotors sliding off?????)
help
(p.s.
help
(p.s.
help
(p.s.
help
Lee
