How to increase range of key remote?
Anyone have any ideas how to increase the range of the key remote, other than replace the battery? Especially now that I have LuxLink, I'd like to get as much range as possible.
Also, it doesn't seem like pointing the key any toward or away from the car makes a difference -- is that right?
Please refer to the photo below for the solution. I don’t think a technical diagram is needed due to the simple nature of the design.
OK, in all seriousness, my most humble apologies, but I just couldn’t help myself with this one. I hope nobody gets offended by this.
I’m not sure there is a solution to the issue. All my best ;-)
So I dont know if anyone knew this, but i was reading alot about cell phones and using it to extend signals. Its in regards to using your cell phone to unlock your car outside the range of your keyless entry system. You need 2 cell phones, so grab a friends. Call each other and answer the phones. Put your friends cell near the remote entry sensor on the car. Then walk however far it is until the remote stops working and hold up the remote up to your cell. Press the unlock button and it should unlock the car . Ive only tried this on my friends 3000gt but not yet on the sc430. I guess whats happening is the AM frequency of the keyless entry system is "transferred " through the phone (which in theory makes no sense because phones pick up vibrational/mechanical waves and converts it into a sound).
I figured id post it here, just cuz JohnnyCake was wondering how to extend the signal. I googled this and people have had mixed results. Some say it works and some dont.
You don't have to hold it to your chin, its about holding the key upwards. For some reason, it works better facing one way over the other. It's only a few feet, but thats an improvement..
http://urbanlegends.about.com/librar...nlock_door.htm
Top Gear tested the 'fillings' theory a couple of seasons ago and found the effect was just as pronounced with one of the presenters who had no fillings as it was with with Jeremy Clarkson...
I was so flabbergasted I tried it myself (I have fillings) and it works. Just walk away until your keyfob stops working then hold it up against your head and try again. Now keep walking away until it stops working again. The distance from the first point is almost double!
