grille questions
grille questions
so when you remove the "L" emblem from the front grille, that small plastic nub that sticks out for a screw is rather annoying. how did you guys remove that? also, what grille options are even out there for the SC430?
On the L emblem though, I used a dremel tool, however keep it mind that once removed there will be a hole there vs the tab. My emblem is actually going back on. Just not into the look even though I painted my grill the same color as the car.
UPDATE
Try these links on grills. Blitz is the popular one though many seem to stick with the stock design.
https://www.clublexus.com/forums/sho...ighlight=grill
UPDATE
The cheapest one will be Blitz for about $250 +paint job, or you can go with chrome Junction produce grill for $500.
Another option will be Grazio&Co, but I think it is more like a refinished stock grill (pretty much the same with what Lee has done to his grill) and it will cost you about $320 (with emblem base tad) to $380 (without emblem base tab)+international shipping from Japan.
J250
04-22-13 07:53 AM
