firm your shft in the sc430 [ a-650-e ]
Old 08-20-07, 06:54 PM
GILLEXUS
GILLEXUS's Avatar
Originally Posted by mikep34689
thanks, talwang, how did you do that ? i have been playing with this for abought an hour
Yea, it took me for ever to post picsalso, but this helped me do it.
https://www.clublexus.com/forums/sho...threadid=73808
That is one clean sweet ride
Mike I re-sent that manual, did you get it?
Old 08-20-07, 07:00 PM
GILLEXUS
GILLEXUS's Avatar
Mike what exhaust is that? That rear tire looks beefer than stock what size?
Old 08-20-07, 08:31 PM
JPI Racing
JPI Racing's Avatar
Very nice ride Mike. Any problem with the belt slippage?
JPI
Old 08-20-07, 11:39 PM
BoostAddct
BoostAddct's Avatar
I'd like more information on this supercharger setup...Any dyno numbers?
Old 08-21-07, 07:36 PM
mikep34689
mikep34689's Avatar
blitz exhaust, rear are 285-30-20 and no belt slip yet with a 280 drive pully @6psi i want to tweek it a bit more just for the hell of it, its 366hp to rear wheels with that set up, it was on a dynojet have the slip around here some where, now i know how to post i will try to find it and post it if interested,
Old 08-21-07, 07:49 PM
mikep34689
mikep34689's Avatar
lookin at that stroker kit jpi maybe when my engine blows i will keep you in mind, have you built one yet ?
Old 08-21-07, 08:40 PM
GILLEXUS
GILLEXUS's Avatar
Yea i would be interested in seeing your dyno. curious to see how the curve is and how the A/F was through out the power band.
Go ahead and try the 2.67 or even 2.55 pulley
Old 08-24-07, 07:31 PM
JPI Racing
JPI Racing's Avatar
Unless we change the drivebelt configuration. It would be hard to hit 10 psi with this set up. Also once you past the 7 psi mark I would be very carefull with that stock timing. What kind of fuel pressure you guys are running at 6 psi?
JPI
Old 05-24-10, 07:37 PM
da-bizket
da-bizket's Avatar
I just did this mod in my 04 SC430 and it worked great! You don't really notice it in drive but, when accelerating the shifts are definitely quicker. I wouldn't say firmer or harsher, just gets into the next gear quicker.
The tranny pan has to be remove so it can be more expensive than just a fluid change. Check pricing with your shop. If you like performance, it might be worth it for you.
Old 05-25-10, 05:56 AM
tfeni52355
tfeni52355's Avatar
Question Gasket Change needed?
da-bizket,
Did you have to change the gasket on the tranny oil pan when you dropped it to change the setting?
Old 05-25-10, 09:49 AM
da-bizket
da-bizket's Avatar
Yes, the gasket has to be changed. A little more work = time = $$$.
If the shifts seem long, especially when accelerating, you will like this mod.
Old 05-25-10, 12:20 PM
petasheep
petasheep's Avatar
Just curious which setting out of the three you went with?
Old 05-25-10, 02:34 PM
da-bizket
da-bizket's Avatar
I went to the third setting and recommend only that one for a noticeable improvement.
Old 10-04-11, 07:22 PM
GammaLex
GammaLex's Avatar
Im still interested in this anyone else done it with feedback? Talwang lol?
Old 10-05-11, 09:05 AM
irokdastar
irokdastar's Avatar
Doing my transmition flush today great info thanks!
Quick Reply: firm your shft in the sc430 [ a-650-e ]
