outside passenger rearview mirror up/down tilt failure
Well, my outside passenger rearview mirror up/down feature finally failed.
When I try it manually on the L/R driver's side switch, the "R" outside rearview mirror doesn't tilt up/down anymore. It only tilts left and right now.
The same goes for when I put it in "R" Reverse. No response for up/down.
I brought it into the dealership for them to take a look at it.
Unfortunately, my 50K warranty has expired and I have 54K.
So they said another SC430 had a similiar probelm and they had to replace the entire outside rearview mirror w/ the motorized motor inside it.
I said if it'll cost me an arm and a leg, I can live w/out the up/down tilt feature.
So it did, the factory (paint color to match) passenger rearview mirror w/ motor was about 500 bucks and labor was about 200 bucks.![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
700 is what they wanted to get out of me but I said as long as my mirror isn't breaking or cracking, I'll live w/ it for now.
anyone else have this similar issue? My car is an '03.
thanks..teeman3
thanks..teeman3
I had the same problem with my '02 and it turned out that the switch was bad. So, before spending $$$'s on a mirror assembly, make sure your switch is working.
Good luck.
Good luck.
Dealer Put A Set On My 06 Two Weeks Ago. They Look Nice With The New Trim That Is Now Perfect , Had A New Windsheild Installed And Re-painted The Front Bumper & Hood, New Grill And Bumper Trim Pieces Everything Looks Perfect For My Trade In...
4200.00 Later
Thanx Wawanesa Insurance
4200.00 Later
My 2003 did the same thing. On reverse the passenger mirror went down but didn't come back up when I came out of reverse. The switch would work left/right, but not up or down. I manually pressed the mirror back into position. The next time I went in reverse, the mirror worked fine. But it happened once more since then. It is working now, but how about this.... is there a way to disable the "auto down tilt" when in reverse?
Eh6174
02-05-23 03:20 AM
HKSC430
06-15-10 11:45 AM
