Hi. Questions from a hopeful new owner.
Hi everyone. I was hoping to purchase a SC430. I have been looking at a low low mileage 2005. I had some general questions if that would be ok.
1. JD Power says it is reliable, but would love to hear the opinions of actual owners.
2. How are maintenance costs?
3. Does a CPO warranty really cover everything like the original factory warranty does? (According to dealer, CPO voids the factory warranty, and starts the CPO warranty the day I buy the car and has 3 yrs or 100k coverage)
4. Anything I should look at/ for before buying?
Thank you!!!
Thank you!!!
Hello and welcome!
Yes, the SC430 has been rated THE most reliable vehicle sold for a few years. There are very few trouble areas if any that can be called a common issue. Early models 02-03 had some clunk issues with the rear end (TSB fixed that), side mirrors, stereos (Code 3 error). Some have complained about the top making creaks which seems to be hit and miss and a few have complained about the battery dying if the car is not driven for a couple of weeks or so. I experience neither with my 02. But the 05s and up are pretty stout cars as the minor things have been addressed.
Maintenance cost is very low other than the normal routine stuff such as fluids ,etc... Dealer of course will be a bit more. The first expensive scheduled maintenance item is the timing belt at 90k miles.
Lee
Lee
Hello and welcome!
Lee
Lee
I have seen/heard of belt service go from $650-$1400.00. In fact I need to replace my timing belt shortly-thought I was going to get it done this past week but the Porsche broke again.
Check around with different dealers as some run pretty decent specials for this service.
I've had an 05 for over a year now and cannot fault it at all.
In the UK slight wheel corrosion is the only issue which I have had done under warranty (Salted roads in winter). Also check the inner front tyre for wear as they dont seem to like high speed cornering...mine were changed at 14,000 miles.
Go for it...
Paul
Go for it...
Paul
Thank you Paul! My search continues. I went in today to do all the paperwork and get this, the salesman tells me "Honey, this car was sold last week. Someone gave you bad information."
And I was in there on Saturday! Oh my gosh, why did they waste my time!? Oh well, the search continues.
Purchased my SC in Dec. 2006 and haven't had one problem after 12,000 miles. Only dislike is the run flat tires which I will replace when worn out. Good luck in your search and I'm sure you will love the car when you find one. Since your in NJ, you might try Ray Catena Lexus. My experience with them has been great.
Tensi, I picked up a clean '04 with 16K miles on it earlier this year,, from "Autolenders" in Berlin, NJ. Their website is www.autolenders.com, and the chap that I dealt with was Damon McLaughlin,,, you might want to give them a look, as I would go back to them in a heartbeat. They currently have 13 SC's in their inventory.
My 2 cents worth.
We bought our 02 CPO with 29110 miles this past May. The car was built in May 2001 it was essentially 72 months old, I saw that timing belt recommended change at 90000 or 72 months so I told them the timing belt needed to be changed under warranty. They hemmed and hawed but changed it. Struts rear deck lid weak so they changed them under warranty.In June car wouldn't start ended up changing alternator under warranty. Love the car. CPO worth it!
travelride
12-01-14 08:29 PM
