Job Design tease is over
Here you go!
First impressions are really very good. The box was really torn up I was pretty worried before I opened but it was packed well enough to get here without damage. I have not tried fitting it but it looks like very good work. The edges are all nice and sharp, no dings or dents. The back bumper is tapped for the bolts. I'm not sure if the foglights are going to require a custom bracket to get them mounted. Clearly better than some of the German stuff I've bought when I had BMWs. The big surprise was how big the outlets for the exhaust are. Much bigger than I thought and much bigger than the dimensions I was given when I asked. I'm using a set of Magnaflow tips and they fit pretty well I laid them in there just to get an idea of how much fabrication it's going to take to get them right. Take a look:
I do believe Job Design aero is the least amount of trouble you should have with installation compared to many companies out there.
The quality, as far as I can tell from the pictures do look very good on the outside and inside.
Good Luck with the install man and post as many pictures as you can as I do hope to be a fellow Job Design aero owner in the near future.
