60K mile Service! what are the most important to do......
hello all, am about to schedule in my 60K miles service.....
what are the most important to do items b/c I would like to save a couple hundred dollars from there (dealer) quote of $700.00.....
here are the ones' I know are very important....
1. Differential Flush
2. Trannsmission Flush
3. coolant flush
4. Spark Plug Change- NGK Iridiums ONLY?????? anyone know?????
5. Oil/Filter change
6. Brake Fluid Flush/Check brakes.....
7. air filter in motor and cabin.....
8. Retorque flange drive shaft bolts?????
what is this,,,,,is it important?
what else am I missing..... thank you....
3. coolant flush
I've never taken a Lexus for service so take my advice with a grain of salt.....
That said I've taken Mercedes and Jags for service and those dealers tries to gouge you if you split up the service. Supposedly the service is a discount, and if you dont take the whole service then you go back to list ricing which is much higher.
My advice would be take the service. If you mix and match and something went wrong that was out of warranty because it wasn't serviced you would hate yourself later.
Thinktwice
04-11-11 09:42 AM
