Couple of Bluetooth questions.....
Every once in a while, the SC430 does not "see" my bluetooth phone. I can correct this by turning the car off and then back on, but sometimes I'm already on the expressway before noticing. Is there a way to tell the car to connect without stop/start?
Also, if I am talking on the bluetooth and want to talk privately (i.e. via the handset and not the speaker), is there a way to do that?
Thanks!
Thanks!
Don't know the answer to the first. You might try deleting the phone and reconnecting it to be sure it is a good link.
On the second point, there is no way, other than stopping the car and turning off the ignition (breaking the Bluetooth link), to do this on the Generation 4 Nav. Gen 5 Nav's have a "Transfer Call" button visible while on the call. This takes it out of the car and into the phone only. You open the phone and hit Transfer Call.
I have an aftermarket Bluetooth kit in my SC430 but, I don't think it matters in this case. I have the option on my PHONE to disconnect the Bluetooth while on the call. Then I can just talk on the handset normally. I have a Palm Treo 700p, if it matters.
