Bluish Light on rear license plate? where....
hello, can someone give me a link on the bulbs that light up the rear license plates. preferably a bluish tint to it.....I saw a GS with one and it look very classy and clean, compared to the white/almost yellowish on our cars. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Other then buying a blue bulb you could just spray the bulb blue. One of the laws in the UK is a rear fog light, the reversing bulbs I could not find in red so I sprayed it red and worked a treat.
If someone else cant point you in the right direction then that will work.
http://cgi.ebay.com/ebaymotors/PIAA-...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/SUPER...spagenameZWDVW
I bought some Piaa's and they look exactly like the newer IS's/GS's.
thanks for the links fellas..... what is the OEM part # for that blub? I know PIAA makes lots of bulbs that are hex shaped but which one will fit "exactly". thanks....
p.s. does the 2007 SC430's really come with that bluish bulb for the rear license plate lighting?
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
It appears that only the person who claims they emit bluish light on his pb sc can verify the info.
Just go with the any of the 194 bulbs as recommended by other members who have posted the links.
I use Polarg M4 194 Bulbs.
http://cgi.ebay.com/ebaymotors/JDM-P...spagenameZWD1V
will the 194 bulbs produce that bluish tint? on that last link you gave me, it says that the bulbs produce a white light???? since you say you are currently using these 194 wedge Polarg bulbs, are the light in the back "bluish"? thanks....
The output will be white, maybe looks very tiny little bluish to some people.
Or you can wait till someone who has an 06+ to confirm if 06+ come with LED license plate lamp.
Although the OEM parts list I saw shows the same parts graphic for 02-07, yet the msrp for 06+ is much higher.
There may be a chance that 06+ sc430s have LEDs.
