High-Intensity LED Headlamp "Conversion" (01-05)
Old 01-09-08, 11:33 PM
talwang
talwang's Avatar
Default High-Intensity LED Headlamp "Conversion" (01-05)
BT, don't be shy and speak up for yourself.
06+ headlight conversion VS this
[links removed]
Old 01-09-08, 11:38 PM
talwang
talwang's Avatar
damn........
[links removed]
Old 01-09-08, 11:55 PM
rominl
exclusive matchup
rominl's Avatar
very nice!!!!!! so the sides are led, but the low beam is also led? or just a ring of led, and then still HID bulb? (i think it's the latter case).
for the turn signal, how does it work? light up white and orange?
and the high beam, it's superwhite bulb? i don't think one single led can be bright enough?
Old 01-10-08, 12:15 AM
FunGuy
FunGuy's Avatar
OverKill, colors dont match. Would be great if it did.
Old 01-10-08, 05:49 AM
bt430
bt430's Avatar
You know I'm not sure what Mike did but whatever it was it's ROCKS!! The guy is the genius of lighting!!
The turn signals are white and then when engaged they kick on amber LEDS. That's the same for the running lights on the front and rear as well.
The dreaded yellowish DRLs are pure white now which I'm real happy about.
You are correct about the low beams. The high beams I'm not sure probably a bulb change with LEDS.
He's invested a lot of money in the latest tooling and sealing technologies in his shop. He's real serious about this stuff. He's also working on a different version of the 06 taillights which I'm anxious to see.
I thought about an 06 conversion for a long time but then I ran across his site and thought custom would be a way cooler way to go.
BT
Old 01-10-08, 06:53 AM
aquanuke
aquanuke's Avatar
BT
Wheres his site?
Old 01-10-08, 09:09 AM
rominl
exclusive matchup
rominl's Avatar
very nice stuff, BT that's some serious work there for sure. it's pretty much a lot of work for EVERY location in the headlights
Old 01-10-08, 10:29 AM
talwang
talwang's Avatar
The led conversion was beautifully done, but I am still shocked by the price tag.
Mike's website address is blocked from cl for some reason, so I just c&p the features of the led conversion.
Features:
- Each headlamp utilizes 75 wide-angle white high-intensity LEDs for the parking lamp and are visible from a multitude of angles.
- Ultra low-profile LED rings are discrete and do not interfere with light optics.
- Unlike lower quality Cold-Cathode Fluorescent (CCFL) rings, LED technology does not require bulky voltage inverters and will continue to operate at temperatures under 50° F.
- Each headlamp uses a combined total of 66 amber high-intensity LEDs, offering better visibility & increased safety.
- Dual LED side-markers illuminate white with the parking lamps, amber with the signal lamps.
- High-beam bulbs are upgraded with HIR-spec Ultra-Premium high output bulbs.
Old 01-10-08, 10:33 AM
rominl
exclusive matchup
rominl's Avatar
ah, thanks rich, nice spec there
Old 01-10-08, 05:31 PM
rclab1
rclab1's Avatar
Default Price?
how much is that headlight,,,,,,is it a direct replacement for the '02-'05 headLight assembly?
Old 01-10-08, 05:48 PM
rominl
exclusive matchup
rominl's Avatar
it is direct plug in. you send in your headlights for them to work on, and then return to you
Old 01-10-08, 05:52 PM
Pearlpower
Pearlpower's Avatar
Very nice. $$$ I bet but the look is great
Old 01-10-08, 05:59 PM
aquanuke
aquanuke's Avatar
--- lexus · 01-XX Z4 SC430 application guide.. ·
[ headlamps ]
INQUIRE High-Intensity LED Headlamp "Conversion" (06-XX)
$1680 High-Intensity LED Headlamp "Conversion" (01-05)
+145 - Matte-Black Paint Finish
+295 - Color-Matched to Factory Paint Code
[ side-markers / side-signals ]
Clear / LED Front Side-Markers
$315/pair Single Function LED
$420/pair Dual Function LED
Clear / LED Rear Side-Markers
[ tail lights ]
INQUIRE Full High-Intensity LED Tail Light "Conversion" (06-XX)
NYA Full High-Intensity LED Tail Light "Conversion" (01-05) -- In Development
Old 01-10-08, 08:01 PM
GammaLex
GammaLex's Avatar
Ouch $1680 not counting painting the inside? www.AACstyle.com does the same work for cheaper and there an approved vendor. Me and Mike over there are working on my 06+ headlights. I guess it helps that there in my backyard LOL
Old 01-10-08, 10:24 PM
rominl
exclusive matchup
rominl's Avatar
let's wait for your headlights to come back and then we can compare the quality. i am not ditching anyone, but AAC didn't have that good of a reputation before.
on the other hand i have seen the work by this company. very high grade that's for sure
Quick Reply: High-Intensity LED Headlamp "Conversion" (01-05)
