Dome Light L.E.D., Door Lights to L.E.D. ?????
which ones? there are 9 LED and 12 LED lights for replacements of the dome lights and door lights? which model of light is it? (194?) will aftermarket LED work? pics anyone? thanks
I have all my interior lights changed out to white leds
The doors use 194 wedge bulbs i used these![](http://www.wardenjp.com/12led5.jpg)
The dome uses BA9S bayonet style bulb but if you use leds the polerity is reversed some may not work I used these for the dome and swappef the wires in the plug![](http://www.wardenjp.com/6hp1.jpg)
![](http://www.wardenjp.com/15flux10.jpg)
and for under the dash you need 74 wedge bulb I used these
![](http://www.wardenjp.com/t5_1led19.jpg)
I like the 194 bulbs for the doors (12 LED), I can find those on ebay.
but what about a bluish tint Dome Light LED? I don't really want to solder wires/connectors together, are there any direct replacements for the Dome lights preferably LED's.
any links? websites?
thanks
thanks
OK, but what's the point of replacing with LEDs? It can't be power consumption, it can't be temperature, it can't be cost, it can't be longevity...is it just to be "different"?
Keith
Keith
Last time I checked, you didn't pay my bills, so I don't need to explain to you why I want to do it. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
6000k color and brighter light output for sure.
LEDs are more energy efficient and last longer. It is important to make sure you get the quality ones.
Also, please do your homework before you buy one.
Don't look at only the bulb number since there are different designs for different applications in your car.
If you don't choose the right design, it will perform worse than your stock bulb.
Plus there's the satisfaction from figuring it out and helping others.
I was joking. lol
It will take more time and work than you expect to find the ideal LED replacement.
I would stay with stock filament bulbs if I couldn't do the led upgrade right.
GammaLex and I bought the led circuit board for a reason, but it needs some work to make it fit.
For the sc430, you will find very tight&limited space there after you remove the dome lamp cover.
For the owners of some other Lexus models, you can actually find the led circuit board specifically designed for your cars like these below.
![](http://www.brm21.com/roomlamp/r_t002-t004.jpg)
chrispy
05-20-10 09:14 AM
