tire mounting
i'm thinking about buying new wheels and tires online. if i do, i'd have to have my sensors moved from my old wheels to the new ones and have them mounted. about how much should this cost? and is it something i'd need the dealer to do. or could any tire store handle it.
thanks
thanks
You also have to make sure the sensors are re-installed on the correct wheel. I was told the sensors are wheel specific. I didn't experience this, but I was told it does create a headache if you mis-match the sensors. (i.e. right front sensor put on left front). I had new sensors installed on a new tire/wheel package at a local shop and then took the car to Lexus to have them reset the TPMS system. They wanted to charge me for dismounting the wheels so that they could read the serial numbers off of the sensors. Fortunately I was smart enought to right them down in my owners manual. Time and money saved!
the lexus TPS system can't tell which sensor is which. it can only tell if the sensors are close to the car or not
OTOH, if you have a TPMS that displays the pressures as individual tires (LF, RF, LR, RR) like my wife's 2007 Chevy Equinox company car (<groan> at least it's free), then this becomes a real PITA. After is was serviced (the company program ONLY allows Firestone and Goodyear <another groan>), we lent the car to our daughter with a slow leak in one tire - it drove her nuts when she filled the indicated offending tire only to have it go nowhere but have a different tire go up in pressure.
Keith
You can also see when you look up these parts on lexus-parts.com, there is a blurb about the sensors being wheel specific.
http://www.lexus-parts.com/parts_det...id=90151&all=Y
rominl is correct. Even though there are four color-coded sensors, it doesn't matter which wheel they are on. Almost any tire store and most lexus dealers will do the work for you.
I buy tires online all the time and have the dealer put them on.
My guess about the different colors would be that they're different frequencies. You need to have one of each so they won't interfere with each other. But, as long as the TPMS antenna (receiver) is somewhat centrally located, it would pick up the signal from anywhere on/near the car. Just my guess though.
i think the reason it matters is each one sends a unique signal telling the computer which tire is which. the battery died in one of my sensors and they were able to tell me which one just by plugging into the computer when i took it in. so if you put them on randomly, they'd still work fine, the computer would just think they were in different positions.
The OEM repair manual only says that when replacing the tire pressure monitor valve, replace it with the one which has the same identification paint collar and have it registered.
Unless that oem manual in pdf I have is incomplete, it doesn't say anything about tire sensors when you rotate tires.
I did tire rotation a few times when I had stock wheels. NO issue at all.
Also, there are 4 antenna and 1 receiver plus each tire sensor has its own part number.
I believe they are only color specific, not wheel position specific.
flash_e_gt
12-14-07 01:57 PM
SGT
10-31-05 11:02 AM
