Sway bar bushing noise?
#31
what size greasable sway bar bushing set for sc430
The Daizens are chronic squeekers - go over the the 2nd gen GS board if you want more info. The problem is when the grease gets wet it essentially dissapears. It seems to really manifest itself in cold weather. My problem was on the front, which I had regreased once already. I just took mine into my mechanic and had him install greaseable bushings up front. I got them from Jegs - Energy Suspension is the brand, and for my GS, the front's are 32 mm. Its only $16 for the pair. I also got a new grease gun and a tube of Prothane grease, which is high-end synthetic. I will now grease my front bushings everytime I get the oil changed.
I just had it done earlier this week, so I don't have longterm results for you, but from other members posts, that is the way to go.
Good luck.
Good luck.
Threxx
Suspension and Brakes
12
11-12-05 08:07 PM
