tpms
tpms
can someone post a pic of the tpms in thier dash , my boss have this car and we are trying to figure out , what's this indicator on the dash, it's a horseshoe shape.
That "horseshoe shape" that you see on the the dash is supposed represent a tire which is low on air. If that light stays on after the vehicle has cycled through startup, you either have a tire or tires with low pressure or problem with the TPMS. Probably wouldn't be a bad idea to at least check the tire pressures and bring all of the tires up the the recommended pressure. After a short drive the light should go out. If it doesn't go out, you should seek tire service. The light staying illuminated after checking the pressure could require more than just adding air to your tires.
