Automatic Windows
Automatic Windows
Question to all SC430 owners,
When you lower both driver's and passenger's windows in automatic mode, which one goes down faster? Also when you close them which one moves faster? I've noticed my driver side is relatively faster. Is this normal or does my passenger side motor needs to be looked at?
BTW, this is on 04 model.
Not sure if it's normal, but it could be something as simple as the passenger side door panel being a little tighter on the door than the driver side. I believe this to be true because I had problems with my passenger window getting the window stripped off of it because of the tight door panel, and the driver's side was fine. If it's not a big delay, it's normal. They should go down closer to the same time though....
rj4510
GX - 1st Gen (2003-2009)
07-14-11 07:22 PM
