Quarter window mod part deux
#32
Typo? That's the only reason I'd be interested in this mod.
#33
The thing is that the rear windows have a molding, which might be damaged if you roll them down first. What I do is roll down my front windows 1/2 to 3/4 of the way and then lower the back quarters then raise up the fronts again.
It’s just an extra step I take as an precaution, my girlfriend lowered the rear quarters without touching the fronts the other day by accident and nothing happened (nothing tore) but for the long run I wouldn’t want to damage any of the seals/moldings on the car
#36
I have LuxLink with the rolldown mod, and it was a nice novelty... but one day my top refused to go down. The window rolldown module had failed and wouldn't allow the system to control the rear windows, so couldn't put the top down. I thought about replacing the rolldown module, but thought hard about it and decided not to. The novelty just wasn't worth the inconvenience of manual control -- you see, when I had the rear windows in the unnatural position I couldn't move the top. This because a pain since I usually use my remote to control the top. I won't miss the rear window control.
#37
Over all I think this is one of the best mods for our cars and I would do it again in a heartbeat, I enjoy begin able to have control over all four windows.
#39
If you are talking about just the relays which the Luxlink uses to control the rear quarter windows, they are just generic roll up modules. In fact, LuxLink just repackages an off-the-shelf model (after doubling the price).
#40
any suitable relay will do, just need to know where i can purchase them,or any electrical stockest on ebay, been planning this mod for a while, finally got a mate whose handy with wiring to do it for me so just need the relays used. help much appreciated
#41
you need (2) 4 pole double throw 12vdc relays,
like this
http://cgi.ebay.com/NEW-RELAY+Socket...QQcmdZViewItem
like this
#42
like this
like this
#43
Can you explain the wiring at the switch a bit more? I see that there is one wire coming out of each relay for the switch, but then what? Do they go to one post on the switch, and then you ground the other? Sorry, I just want to make sure (since I'm now in my garage almost done with this)
#44
well you are going to have the two wires coming in from the trunk and you will need to power the switch, I tapped into the 12v outlet in the center console, if you remove the heated seat plastic cover you will see the wires running to the back of the 12v outlet, just tap into that wire and you should be good to go.
That's why you need a momentary switch, the switch will have power running to it at all times via the splice. As you toggle it back and forth it will give power to the relays allowing you to lower or raise the windows.
hope this helps
hope this helps
