Need Help! Radio-vol/bass/tre/mid/fad/-will not move.
Can anyone help? driving to work one morning playing with radio on steering wheel. I cannot ajust volume/ bass/ Mid/ tre/ fad/ asl/ nothing.---but I can change the channel of the stations.... also the volume goes up when i speed up and get quite when i slow down...
is there a reset button i can try....already check fuses ok....disconnect battery...pull fuse out for 2 hrs....
i even took the **** out to see if the was anything wrong....
all i can do now is turn it on....change station...and fm/am/disc....
please...need advice
fuji
fuji
It sounds like the usual ML amp problems - it would cause a variety of problems around the sound controls.
Mine packed up totally last year and an OEM replacement was £1500 ($1700+)
I picked up one on ebay from the US (I live in the UK) for £350 ($400) but they will work on either LHD or RHD SC's
Fitting it is a pain, and you'll have to remove a lot of the boot (trunk) liner - but its pure plug and play.
My only recommendation is to get a refurbished device, the one I got had already been back to ML so should last another 10 years at least.
Thanks
Thanks
tuterz
06-15-08 12:31 AM
