Broken ashtray door
I recently had the dealer replace my radio and now the ashtray door doesn't work properly - not at all actually. When I press on the door to open it, the door just goes down a little, and back up to the flush position, but doesn't open up by itself. I can move the door freely to open and close it manually. Does anyone have any advice? Could the radio replacement procedure have caused this or just a coincidence?
Thank you
Thank you
Most likely the installation was not correct. Perhaps there is something underneath it that is blocking the ashtray from operating properly.
I would recommend removing it and inspecting keep in mind to close the ashtray before removing or installing the trim piece. Removing the seat warmer switch and gear selector **** first before removing the trim piece.
bryan767
SC- 1st Gen (1992-2000)
04-07-11 10:06 PM
