Can I add Blue Tooth (BT) to my 2003 SC 430?
i just have a few questions about the Parrot CK3100 , does it automatically mute the stereo when there is an incoming call? and does it automatically connect to your phone when you turn the car on? thank you for the pics and info
Yes. It mutes the stereo on incoming calls and automatically connects to the phone you paired with the system. It takes about 10 - 20 seconds to make the connection once you turn on the car. You don't have to do anything. Just turn on the car. Also, it automatically downloads your phonebook into the unit. The only thing you have to do is train the system to recognize the phone numbers you want to call using voice recognition. My wife only has about 10 names and numbers she wanted to use with the voice recognition. It took about 10 minutes or so to do this. When you want to call using voice recognition, you just say "phone", wait for the beep and then say the name. When you receiving an incoming call it shows the number on the LCD screen and also announces it audibly. To disconnect a call when you're finished, you can press the red button on the unit or say "hang up".
I tried to upload the pictures. But even after I changed my camera's setting to take small picture to email, very low resolution (VGA), each file was still just a little too large to upload. If someone can help me with this, I'll take some more pictures and upload them.
Thanks, Mike
Thanks, Mike
http://www.microsoft.com/windowsxp/d...powertoys.mspx
Right click on file, pick size, save. Simple.
ShellyGX
06-18-18 04:25 PM
