need help luxlink installed in 2005 sc430
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I need some advice from any member that did there own install of the latest
version of luxlink for a 2005 sc430 . In particular I am interested in your selection of wires in the drivers door that you would of spliced the luxlink harness into the car harness, Weny and my self were doing the install on my 2005 where we removed the black tape covering the wires that we needed to splice into we found more then one set of red with blue also several sets of green with white . Would really be helpful if some one with same year as mine 2005 would like to compare notes and see if you had any difficulty . Right now we have an issue with the red and white stripe wire from luxlink to the red and white wire of the harness, when we solder the luxlink red and white in the courtesy light stays on so we are unable to lock the car to start the remote top sequence because with the courtesy light on the doors wont lock.
Buddy
Buddy
try a search ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
hope you used my updated install instructions
https://www.clublexus.com/forums/sho...d.php?t=235281
I am guessing thats not the right wire
theres alot of wires that look the same in that harness. Used a voltemeter only way I got it done right.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
tuterz
06-12-16 05:19 AM
