remote Fob not working
hi, have 02 with 110K....
both of my remotes do not 'work'.... batt seems ok.... if both are not working at the same time, i figure it's the receiver side/car....
i do have the luxlink by lux motors..... steve says it shouldn't have anything to do with it since their system operates on received sig via the main receiver ?....anyway, what's the differential diagnosis here?
the LED does light up on the keys....
jim R
jim R
Sure, it sounds like a coincidence that both batteries would fail at the same time, but both were probably installed at the same time so it's possible. Before going through some hoops, why not spend two bucks and replace the batteries, just to eliminate that cause from the equasion. The "send" fails long before the LED, in my experience.
resolved
yeah, it was both batt being bad at the same time....
cr1616 , $4 a piece at radio shack....
all good now. should of checked the obvious first....
thanks guys...
have 110K, 2002 model, probably should do timing belt....
although i have a nsx from '95 with 63K that should have the timing belt done first.... both sitting in the garage so....
jim R
thanks guys...
jim R
joeker
07-15-09 06:02 PM
