Highest mileage SC430 here?
#47
High Mileage sc430
I have over 157000 miles on a 2002 SC430 had water pump timing belt done at 118000 in process of replacing worn parts in front suspension after tearing suspension only real problem i saw is the bushing on the lower control arm #2(caster arm) was worn pretty bad. No radio problems no top problems
#48
Still looking for shocks for the rear. I don't want coilovers.
#49
I missed this post from you Mandy. Our cars met when the delta between them was about 60 -70 k miles. I am catching up. 92,500 or so at this point but still pretty junior compared with some of the really senior cars around here. Timing belt water pump done at 70 k miles. Recently replaced both front shocks ( kyb = OEM) while rears were done under CPO warranty when the car was only 4-5 years old. Also got the tranny pan gasket replaced due to minor weeping six to nine months back.
That's about it.
That's about it.
#50
2003 145,000 miles. Roof works sparingly, but its winter now so ill tackle that in the spring. Radio works, but front screen burned out so will be swapping it out with aftermarket unit at some point. For now the phone to tape deck adaptor work just fine :-)
Still love my sc430!
