WEIRD: Parking Brake light comes on during deceleration -- any ideas?
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
I don't use the parking brake. Lately, the parking brake light has come on during deceleration, albeit randomly, maybe two or three times a commute, although some commutes not at all.
This is definitely a deceleration thing and not a brake thing. To check, I downshifted without touching the brake and got it to happen once.
I have applied the parking brake and released it, making sure that it releases fully.
Any idea what I could try before heading to the dealer, where I know I could not get it to repeat????
-- Johnny Cakes
-- Johnny Cakes
-- Johnny Cakes
-- Johnny Cakes
![Yikes!](https://www.clublexus.com/forums/images/smilies/yikes.gif)
Buddy
I thought I read in one of the shop manuals that the sensor for the parking brake is actually in the parking brake pedal assemble . I could be wrong but I remember when we were installing the luxlink in my car I noticed a switch in the brake assemble when we peeled back the side cover to gain access to the ecu. I would check for a loose wire and or a to sensitive adjustment .
Buddy
Buddy
isn't the parking brake and regular brake the same light? if so, maybe your brake fluid is low and when you decelerate, the fluid all rushes to the front of the reservoir, causing it to dip below the sensor.
Jason702 is exactly right on the money. I have a 2004 SC430 that experienced the exact same thing. I mentioned it to the service advisor when I took it in for routine maintenance and they said that the fluid was low. They topped it off . . . problem solved.
The low brake fluid level seems to trigger the warning light easier in the SC 430 than in other vehicles.
The solution is to top up the brake fluid abit.
+1
low brake fluid
also if your brake fluid is low, that might be a good time to take a look at your brake pads. Might be getting a bit thin.
If you fill your brake fluid reservoir now, when you replace your pads, be ready to have that reservoir overflow once the thicker pads are put in and the caliper pistons sit further back.
low brake fluid
Hey, guess what? My brake fluid was a few ounces low. I topped it off today and will report back for posterity whether that fixed the problem.
Thanks guys--checked brake lights, but never would have figured fluid.
