"VSC" and "VSC Off" always lit
First, I have one bad TPM which is throwing light on dash. Replacement on order.
My indy hooked up his machine and did not find any codes thrown.
Is there any correlation between the TPM and the VSC and VSC Off lights?
Does anyone have any ideas besides go to the dealer?
Thanks
al
Thanks
al
TPMS sensor and the VSC/VSC Off shouldn't be related.
I've had 3 of my sensors go bad, I've had a flat, and I've had a slow leak. I'm INTIMATELY familiar with that damn TPMS light!
I've had the VSC/VSC Off lights come on before...once due to a bad O2 sensor and once due to a not-screwed-on-three-clicks gas cap (thanks to my lovely wife). Both times I got the two VSC lights along with the Check Engine light. And both times the car was throwing error codes that could be read via the OBD-II interface.
i had a tire pressure sensor go bad. after they replaced it, the VSC/VSC Off light was on when i picked up my car. they said they had to reset it. after they did, i had no problems.
mandyfig
06-20-22 04:29 PM
