Pictures blitz controller install in ash tray
Well not really cos lag is lag.
IE if your playing an online game even though your lagging it jumps to catch up. So at some point your at the correct point. Just you had a blip and then it rushes to catch up.
Where as the other players just go frame by frame smoothly. But all the players are going the same speed even the ones that are lagging, ie a lagging player cant then be faster then the others if he stopped lagging.
When I turn on the controller I do not get a beep unless Its not real loud and I am not hearing it. When I turn on the car the controller is off when I turn on controller it will remember the last setting it was at unless I turned off the controller before I shut the car off. In that case it wii default to eco mode.
Either way I have to turn on the controller and I dont think mine is beeping. I did not notice any slats or opening in the back of the plastic controller case for the beep sound to get out. I do have it set flush on top of an old piece of rubber mouse pad . What was the model number of your blitz unit? My car is a 2005 . I like your tire set up with the pressure and temp setting . was it very expensive to buy and install
Buddy
Buddy
I am using the same one you are using.
According to the installer at ASAA Racing performance shop here in Houston, one of the plugs wouldn't go all the way into stock harness plug smoothly, so it needed a bit trimming to fit perfectly.
More info about the TPMS can be found on tirerack.com.
http://www.tirerack.com/accessories/...09S.TPMS&ID=55
If you google it, you will find it also received some Japan RF certification.
You can disbale your stock TPMS and use this one instead when your stock sensors go bad.
Am I the only one here who has installed the reverse cancel harness?
