asanti af122
hi i just received a set of asanti af122 wheels for my car but the size worries me.. the front is 20x9.5(tire is nitto-245-35-20) and the rear is 20x11(tire 285-30-20). my car is dropped with tein s.tech springs... i was wondering if these will fit???![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
p.s i now have 245-35-20, 255-35-20, 20x8.5 offset +35 all around. and no rubbing of any kind!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
You will have to trim the front liners too. It's possible you might have to remove the metal trims strips also (very easy). I have 295's on 11's in the back and they required less work than the fronts.
My size and offsets are as follows:
Front is 20 x 9 +28
Back is 20 x 11 +35
Front is 20 x 9 +28
Back is 20 x 11 +35
He can't even posted the sizes correctly.
the front is 20x9.5(tire is nitto-245-35-30) and the rear is 20x11(tire 285-30-20)
The front has 30" tires???
p.s i now have 245-35-20, 255-35-20 offset 8.5 around. and no rubbing of any kind!
Do you know your front and rear tires have different diameters???
And what kind of offset is 8.5?
Probably just lots of typos here.
You need to post both width and offset, so members here can help you.
hi i just received a set of asanti af122 wheels for my car but the size worries me.. the front is 20x9.5(tire is nitto-245-35-30) and the rear is 20x11(tire 285-30-20). my car is dropped with tein s.tech springs... i was wondering if these will fit???![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
p.s i now have 245-35-20, 255-35-20 offset 8.5 around. and no rubbing of any kind!![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Why bother even asking if they will fit just put one on and see
no one can say if they'll fit without knowing the offsets. that's the most important thing to know. did you buy them used? if so, what kind of car were they on before?
