02 Sc430 Oil and fluid question?
Okay.. so im trying to get the Purple Royal ATF fluid into my sc how many quarts would i need?
and also.. i want to use the Purple royal Purple ice for my coolant and it says i need 50% half and half so... how many bottles would i need to buy to fill that up?
My 05 manual says engine coolant capacity is 9.9 L or 10.5 qt. ATF capacity is 1.8L or 1.9 qt.
and isnt purple royal ATF better since its Color purple and full synthetic?
I buy it from Toyota,
that’s the thing, I put synthetic oil in my engine but when it comes to my transmission I only use the Toyota stuff, I dunno, you'll have people on both sides of the fence on this one, I was told by a Lexus Master Tech that he has seen and heard nothing but great things about the Toyota ATF and that had occasionally seen/heard of problems when individuals had used other oils in their transmissions.
Now for the engine and differential he recommended various products from regular oils to synthetics but he told me to stick with the Toyota ATF fluid for the transmission and power steering parts.
And ill tell you one thing..
Using purple royal oil.. it made my car run soo much smoother..
and the purple ice!! my car now doesnt smell burnt when i walk by the front of the car after i get done driving it.. it acusally smells fresh..
I switched to Redline D4 and have had no problems what so ever.
I use a vacuum pump and suck it up the dipstick tube every other oil change. Refill with fresh (2quarts) + or - . Mobil 1 in the engine and Redline every where else.
Toyota in my area gives a discount if you buy 4 qts or more. Last time I purchased it was 4 bucks a qt.The LS has a drain on the tranny to remove close to 2 qts every 15000miles, not sure about the sc, I haven't been under her yet.
TMaxxTim
05-24-08 06:32 PM
