Retrofit oem bulbs to led festoon style
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I am going to retro fit my map lights to take a festoon style 6 led super white 31 mm led assembled on a board that fits inside the festoon holder and has cone ends just like a fastoon bulb would have . My plan is to remove the map light lens then take out a screw on either side. Gently pry out the entire map light assemble. there is a connector that i will disconect that will allow me to remove the map assemble to take to my work bench. Once I have it in hand I am going to remove the the oem style bulb assembly as well as its holder. I will then try and fit the festoon style holder keeping in mind that I will need room once installed to snap the led festoon board into the socket and then be able to fit lens in place and be sure it will close I will use the original wires from the oem style bulbs . There is the nav microphone inside and on top of the map light . I will have to make sure I dont disturb the microphone. I have allready bought fastoon style bulbs that are retrofitted with 6 super white led lights that point directly down. If it works out as I anticipate I will have a significant increase in real usable light when I want it , I also know that the led will also dim as the original oem bulbs would dim when you would set the alarm. If any one else has tryed to do what I am about to do any pointers would be appreciated. The led's use less electricty and more importantly generate no heat. They will be replacable if a burn out same way as the oem bulb would be replacable. Since there is six led in each board/bulb its not likely that they will all burn at once and since they supply so much more light with less electricty I might not notice a led or two out. I have been told they have a very long lasting life and no heat
Buddy
Buddy
Is the diffuser cover a part of the plastic lens that I remove in order to gain access [ how do you remove the diffuser from the lens]
Where do you get the LED lights?
satz
12-24-12 06:08 AM
Wald GS
GS - 1st Gen (1993-1997)
12-16-09 02:27 AM
