Air Conditioning Issue SC430
Old 03-13-18, 03:23 PM
VVTiBob
VVTiBob's Avatar
See this thread https://www.clublexus.com/forums/sc4...-then-hot.html posts #6 and 8. After doing the steps in post #6 the display will light up all of the LCD segments four times. Then any error code(s) may be displayed..... OR the system may do a self check 0-10 with the vents and blower.
Don’t be concerned if 21 and 24 come up AND you are in a garage. Those are solar sensors but they do interface with the AC?
To cancel the self test press the OFF button.
There are a number of components besides the compressor etc....and I assume you checked all of the associated fuses?
Old 03-14-18, 11:00 AM
RZPhyxit
RZPhyxit's Avatar
Originally Posted by DshngDaryl
So from his diagnosis, it sounds like he thinks the compressor went bad and kind of "exploded" internally. That sent little bits of compressor into the system and in the condenser (which looks like a radiator and is in front of your radiator)
The normal remedy is to replace the compressor, the condenser and the drier & vacuum down the system. Now the real question is, did your compressor really go bad?
Do you find you meet these three criteria? https://www.yourmechanic.com/article...-ac-compressor
Out of curiosity, out of the $1600, how much did he say was parts & how much was labor?
Just picked up my vehicle; with further detail on the AC: Mechanic stated: "The shaft of the compressor is broken. If you reach in, you can manually turn it; whereas it should have resistance tension. Somewhat rare to have this occur. Not a mouse/rat causation, just age/wear and tear. So if the compressor needs to be changed, the condenser is also replaced at the same time" The Denso (aftermarket, but producer of the OEM Lexus parts is used, they run about $300 each for the Condenser and Compressor". So that would leave $1000 as the Labor. I'm not supposed to use the Defroster as it could also trigger the Compressor to dehumidify the air, or the AC button in the meantime.
Following VVT1Bob's pictorial instructions for the Self-Diagnostic test of pushing the AUTO and R/F switch concurrent with turning the Ignitions switch ON, I get Code 23. (Thank you VVT1Bob, I read your other posts on the looking at the fuses first. so I will also do this, but am I really up a creek and facing this expensive repair?
Old 03-14-18, 11:54 AM
Bgw70
Bgw70's Avatar
here are links to the parts you were told you need.
looks like he is charging you $1200 for labor. Your mechanic is very expensive.
Good Luck!
https://www.rockauto.com/en/catalog/...condenser,6708
https://www.rockauto.com/en/catalog/...ompressor,6628
RZPhyxit (03-15-18)
Old 03-14-18, 01:18 PM
DshngDaryl
DshngDaryl's Avatar
So I very much agree with BGW. I think this is a good time to get a second opinion. You may want to take it to an AC Specialist. They can probably get it repaired with less labor hours, since they do so many. Though we own Lexi, the repair is essentially the same as it is on a Toyota.
Ask the new company if you need to replace the condenser. If the compressor didn't imploded and only the shaft went bad, you can save some money by NOT replacing the condenser. There is a risk that you will have to do that in the future, but you can put it off now and take a gamble.
Usually in these circumstances the company has to:
1. Suck out all the old R134
2. Replace the compressor
3. Replace the condensor
4. Replace the Drier
5. Vacuum out all the moisture from the system
6. Add PAG Oil
7. Replace the R134 refrigerant
RZPhyxit (03-15-18)
Old 03-15-18, 11:46 PM
RZPhyxit
RZPhyxit's Avatar
Default Encouraged by bgw70 and You........Checking Yelp sources in Orange County, CA
6. Add PAG Oil
I didn't think of AC Specialty repair shops, and armed with the prices of the parts from bgw70 I will investigate this option. If the repair is significantly lower I would go ahead and replace both the Compressor and condenser; the mechanic did mention something about metal pieces pushed into the condenser.... I will update my post as I pursue this.... Thank you Club Lexus and to all who respond so quickly to Novices like me
Old 03-16-18, 10:38 PM
texsexlex
texsexlex's Avatar
.. try DiscountACParts......it's been a couple of years, but I purchased compressor, condensor, accumulator,drier, expansion valve, o rings & oil for $320, then another $350 for labor
Old 07-01-18, 02:17 PM
Hwdrook
Hwdrook's Avatar
Hi all,, having a weird issue with my '02 SC430 AC. When input he AC on it will constantly switch between the dash vents and the floor vents,, very frustrating. Does anyone know what might be causing that? I've never seen this before in any other car I've had so I'm not sure what the deal is. Im thinking it may have something to do with the vacuum hoses but not sure. Anyone have an idea of what's going on???
Old 07-02-18, 09:42 AM
DshngDaryl
DshngDaryl's Avatar
You should start a new post about your problem. You will get a much larger response.
Also, you can do a search on this forum for "Blend Door" This kind of sounds like your problem, so it might give you a lot of the information you are seeking.
Now sure how to do a search? Follow the first part of this post (you can skip the advanced part) https://www.clublexus.com/forums/sc4...430-forum.html
Old 07-02-18, 10:40 AM
Hwdrook
Hwdrook's Avatar
Ok I hear tht. I'll make a new post about it. Thanks for the help!!!
Old 10-04-18, 08:07 AM
AUTOVID
AUTOVID's Avatar
Working on 2004 SC430 80K miles. checked all blend doors. Replaced AC compressor. Down to the expansion valve. Any help with an expansion valve replacement on SC430?
Old 10-04-18, 10:18 AM
DshngDaryl
DshngDaryl's Avatar
I have never done it, but I hear it is a bear to do. You can watch this video. This guy with a GS430 made it look easy. I know the 430 and the SC have the same engine, but I don't know if the AC system is the same.
Old 06-11-19, 08:14 AM
rscharf
rscharf's Avatar
17 years and 95K miles ago this month I drove my 2002 off the lot. I was searching the forum about AC issues since I thought during our very hot Houston weekend that the normally ice cold AC was running a little warmer. The passenger side didn't feel as cool as the driver's side. I don't believe anyone has ever touched the AC system, I know I never had any issue with it prior to this.
This morning I stopped by a small mechanic's garage and had them check the freon level. It took 2 cans. I hope there's no leak. He asked me to drive down to a wash bay of the self service car wash right next to his shop and he soaped down the condenser, saying it was dusty.
It's back to being ice cold, crossing my fingers for no leaks.
Old 06-11-19, 09:13 AM
VVTiBob
VVTiBob's Avatar
Please keep us up-to-date on this issue. I’ve noticed mine doesn’t seem to be as cold as it use to be, but it’s still working well enough for my needs, or maybe it’s just me.
Old 06-12-19, 04:04 PM
stevemcb
stevemcb's Avatar
My AC blows Ice cold on my 07. And glad of it in FL. The AC on these cars were great.
Old 07-30-19, 01:09 PM
rscharf
rscharf's Avatar
Well, the two cans of freon lasted just over a month and then one night I noticed there was no cold air at all out of the AC.
Dealership started to pressurize the system to look for a leak and they told me the compressor was leaking bad.
They replaced the compressor at 97K miles and 17 years of driving. As an aside, my 2002 has a build date of 12/2000 and I am the original owner.
Quick Reply: Air Conditioning Issue SC430
