Surprising things you learned about the SC long after buying it
Old 08-03-10, 08:32 AM
  #91
antigeek
antigeek's Avatar
Originally Posted by KBALL
Bump.
I really like the set button (near up/down vol) on the steering wheel for radio volume control.
I drive 90% of time with top down, and i set that button for loud volume for when i drive fwy speeds w top down. This way i can instantly jump the volume when reaching 75-80 after city driving at lower volume
Wow -- I never considered this. I thought everyone used that button as a handy mute button. I got that tip from those who had problems with the first ML systems: some 2001 builds (March & June?) had an issue where the system would magically jump to FULL volume.
Glad I never had that problem, but I use it for when I get phone calls. That's for those of us w/o Bluetooth integration...
Old 08-03-10, 08:34 AM
  #92
antigeek
antigeek's Avatar
Originally Posted by pageme1911
Hey all,
I found out the other day that the top has what appear to be a failsafe component. My top stoped in mid air and would not respond after this. I knew there could not have been a problem because it has been working fine. Well, instead of not moving the car, I decided to do so. To my surprise, the car started to beep and the top went down on the frist attemp of closing. Now, the big question is what made it stop in the first place? However, it is working fine so far.
pageme1911
The system stops top operation when the car exceeds 3 MPH. Let go of the button, stop the car, and try again. As long as you don't exceed that speed, you can creep out of a parking spot and the top will still go up/down.
Mark2002 (05-03-19)
Old 08-03-10, 10:13 PM
  #93
Pearlpower
Pearlpower's Avatar
The one thing that stands out-how surprisingly well and neutral it handled once coilovers and wheels were installed.
Caflashbob (03-20-23)
Old 08-05-10, 04:58 PM
  #94
dag8882
dag8882's Avatar
Originally Posted by scdroptop
I used the headlight levelers/adjusters for the first time and the headlight washers just messing around with the car the other day. These two features are often underestimated but are very cool!!
how would one turn on the headlight levelers? & just what exactly does this feature do??
Old 08-05-10, 07:50 PM
  #95
scdroptop
scdroptop's Avatar
I searched when I needed to do it, and it was both in the owners manual...I think 356-358 on my 2005 owner's manual. I believe others said it was like 363.
Also try this post-very helpful from the experts:
https://www.clublexus.com/forums/sc-...ealership.html
Old 08-10-10, 03:28 PM
  #96
huy33
huy33's Avatar
This weekend my friend and I were amazed to find out that the seat belt buckle light up at night. It's the seatbelt part on the right side of each seat where you put the seatbelt in. There's these two little clear pieces that light up so you can guide your seatbelt into it to lock.
Freaking cool!!!
I have an 09 so if this isn't on all year models then I have to go take a picture.
Old 08-10-10, 03:40 PM
  #97
VVTiBob
VVTiBob's Avatar
They've lit up since the 2002 version.
Old 08-10-10, 04:57 PM
  #98
IStoSC
IStoSC's Avatar
Default enlighten me!
Also, the emergency top down, and security features of this car were well ahead of their time!!
Scdroptop, what are you referring to with these two features (this thread is my favorite and I'm always craving knowledge here)
Mark2002 (05-03-19)
Old 08-11-10, 04:15 AM
  #99
gripau1
gripau1's Avatar
I still can't figure out how to lower the rear windows when the roof is up? Anyone?
Old 08-11-10, 06:30 AM
  #100
Solman
Solman's Avatar
Can't do it without luxlink (no longer available) or wiring separately.
Old 08-18-10, 06:03 PM
  #101
cjs18
cjs18's Avatar
This is a fairly subtle feature but I discovered that if you hold the ML CD changer's repeat (RPT) button down a few seconds until you hear a beep it will repeat the current disc rather than the current selection. You all probably knew that, eh?
Old 08-18-10, 07:03 PM
  #102
KaiserSea1
KaiserSea1's Avatar
I really hope at least one of these is not already listed.
1. If you hold down the AM and disc buttons, the rear antenna is ejected.
2. If you hold down the FM and disc button, the secondary antenna in the windshield cuts power and the rear antenna stops auto adjust.
3. If you turn the dash dimmer all the way on the GPS no longer goes into night mode.
4. The GPS uses the same DIAS controller designed for the bradly fighting vehicle. It auto calibrates position based on speed and wheel turn sensors without a GPS signal. The contractor lost security clearance for selling this to Toyota. The DOD at the time wanted to be able to disable GPS, and prohibited auto correction in non-military systems.
5. The SC430 price was raised $6000 in the US and $8000 in Europe to avoid perception as a cut rate car.
6. If you hold down the traffic button it will tune any emergency station.
7. If you really truly love your car, it will in fact love you back.
The following 2 users liked this post by KaiserSea1:
alex2016g (03-26-17), TitanG545 (06-25-19)
Old 08-19-10, 06:01 AM
  #103
Habious
Habious's Avatar
I tried #7, but I burned myself painfully on the exhaust tip.
novon (07-31-23)
Old 08-19-10, 08:56 AM
  #104
VVTiBob
VVTiBob's Avatar
LOL Habious, I fell outta my chair on that one.
Great stuff Kaiser... didn't know a couple of them.
Old 08-19-10, 02:43 PM
  #105
JohnnyCake
JohnnyCake's Avatar
LOL -- Best post of 2010!!
(next time, use "protection")
Quick Reply: Surprising things you learned about the SC long after buying it
