Post the most recent pic of your SC (merged threads)
#1217
www.sewellparts.com bro!!! Been thru this before... ... You can do it! Good luck! Post pics when finished!
#1220
Wow! That looks fantastic! You can run a 3" duct out through the space to the side of the headlight into the area in frint of the radiator. See my post for DIY BFI I did. If you don't want to cut anything a 2" duct will fit. You can also cut a hole through the wall into the fender linrr chamber to have dual supplies into your custom airbox.
#1226
#1230
MrMark, looks awesome! I love my Weapon R Secret Intake. I kept the OEM airscoop to give two paths for cold air entry. Did you run the hose behind the headlight too? Mine was a tight fit and had to dremel out about an inch of the headlight firewall after removing the headlight "drape". I was able to pull the hose all the way to the filter. I ran my port and hose to the space under the front lip but your's looks very awesome into the grill mesh. Also the LED's look sweet!
PS. I also put the fancy port on after the install. My port looks much better than the last photo now.
