2004 SC430 Daytime Running Light Change
#61
I believe 4500k or 4000k. I got the equation from this lighting specialist on my red 02 and my low beams did match my high beams, remember the DRL runs at 50% strength, so in essence, 8000k+ at 50% will look similar to the low beams. Once again, they are only on at the same time when your high beams are on!
The two you really want to match are your fogs and low beams.
this time around, I think I am going to do the same color temperature for all three sets, including my little 168 bulb (your 2006+ cars don't have) and be done with it!
#62
You can NOT put D2* bulbs in 9005 sockets plus the fact that true HID bulbs also need ballasts to fire up.
The DRL bulbs he used were LEDs not HIDs.
Stock HID is 4300k. Your 06 uses D4S HID bulbs for lowbeam.
If you like the super white look, stay with 6000k. Anything higher than 6000k up to 12000K will start to look blue to purple.
I have the 9005 LED DRL kit from vled. I believe vled kit is what most people use here on CL.
The color look a bit blueish in pics, but it looks super white in person. My lowbeam is 6000k PIAA D4S.
https://www.clublexus.com/forums/sc-...d-drl-mod.html
You can probably use 9005 HID conversion kit, but you need figure out how to get full power in order not to destroy ballasts and HID bulbs as drl only runs at half power.
Finding where to put the Ballasts could be a problem since room is very tight there.
As for foglight, I have 6000K Philips H3 HID kit but any H3 HID conversion kit will suit your need.
If possible, you should get a HID conversion kit that comes with slim digital ballasts.
My installer had a hard time finding a good spot to secure my Philips ballast on the driver side while installing HID fog.
#63
...As for foglight, I have 6000K Philips H3 HID kit but any H3 HID conversion kit will suit your need.
My installer had a hard time finding a good spot to secure my Philips ballast on the driver side while installing HID fog....
#65
Just for reference:
#67
this is a ol' issue that i answered back in 1/10. i didn't want some deadhead in dc tellin' me to drive around daytime w/drls. got good repore w/dealer but just for kicks he shows me the road. came back a couple days later w/a "tech service info bulletin" dated 6/22/01 (got from this so/so forum)(just hate the gumshoes)!!! anyway it's the customize function/diag program card ver 8.0-ssoo4-01. tells the dealer how to deact the drls. he did & com'p the charges. goodluck. lf
#68
hahaha In short, I believe he said a dealer disabled it for him lol you could always just take out the bulbs. I did that with my side markers.
I love my DRLs since I've changed the bulbs to LEDs, it looks so good: https://www.clublexus.com/forums/sc-...l-think-2.html
#70
tomtsops
Lighting
01-01-08 08:32 PM
KINGPING
10-31-05 09:37 AM
